Engine Cover Off
Old Aug 10, 2011 | 10:47 AM
mlfca's Avatar
Engine Cover Off
So I took off the engine cover as I wanted to see the entire engine and get rid of the eye candy. I put the two bolts back into the intake as it looks like they go directly through the intake.
A few less pounds in the front of the car can hurt. Have others done this? Just curious.
Old Aug 10, 2011 | 10:53 AM
Tommy K's Avatar
Post a pic. Haven't taken mine off yet. Some engines look great with covers off, others not so much. I remember my G8GT had a huge engine cover, but the kicker was, underneath was a thick rubber pad to keep noise down. That and a ton of heat in I'm sure. Looked great without it though so it stayed off.
TK
Old Aug 10, 2011 | 10:55 AM
phatboislim's Avatar
no pics no care
Old Aug 10, 2011 | 12:01 PM
Xpcgamer's Avatar
no pics no care
Bro you crack me up
Old Aug 10, 2011 | 06:01 PM
Xpcgamer's Avatar
BTW here is my 7th Gen with no cover.
Old Aug 10, 2011 | 06:47 PM
NmexMAX's Avatar
dot dot dot ...
I vote no cover. Love the bare look for the A35.
Old Aug 11, 2011 | 04:23 AM
looks gangsta
Old Aug 11, 2011 | 06:09 AM
mlfca's Avatar
I also took the cover to the left off as well. It would be nice to see fluid levels.
Old Aug 11, 2011 | 06:58 AM
NmexMAX's Avatar
dot dot dot ...
It's just sexy, that IM, those CVTC's on all 4 cams ...
Old Aug 11, 2011 | 03:18 PM
sonomamax's Avatar
engine cooling
will this not affect the cooling of the engine.
Old Aug 12, 2011 | 06:58 AM
mlfca's Avatar
That depends. You could argue that taking the cover off allows less heat to be trapped close to the engine. The hood blanket looks to be thick enough to handle the heat so you don't destroy the paint on the hood.
How much engineering goes into that cover? I assume some to make sure it does not melt but I would assume it's main purpose is eye candy. (Based on how thick it is, noise suppression would also be a consideration)
I also understand that engines today are designed to run optimally at certain temperatures (Hot) but I doubt the cover will significantly impact the overall temperature of the engine.
Old Aug 12, 2011 | 07:47 AM
Shift_Max's Avatar
Looks better with the cover IMO
Mar 12, 2020 12:06 AM
Max139617
Sep 20, 2015 07:25 PM
Max139617
Sep 20, 2015 07:09 PM
tardrex
Sep 11, 2015 07:35 PM
jfl330
Sep 4, 2015 01:44 PM
