Wire color/pin in rear view mirror harness for hardwiring pwr/gnd for radar detector?
Old Nov 30, 2011 | 08:02 AM
wope's Avatar
I've searched, but couldn't find anything. Does anyone know which pin and/or wire color the power and ground wires/pins are in the rear view mirror harness? I am planning on hard wiring my radar detector there.
Thanks in advance!
Old Nov 30, 2011 | 02:59 PM
Jbling700's Avatar
If i were you, just tap directly into the fuse box... This method is way better and there is no wire splicing required... go to an auto store and buy a ATM fuses tester... test all of the fuses and see which fuse doesnt light up green on the tester... after you found a fuse that doesnt light the fuse tester green, start your max and see if the same fuse you tested lights up... if it does this, then thats the fuse you want to tap into... you can stick the positive wire into the slot... for a cleaner installation, buy an ATM fuse tap in autozone or advanced auto parts... just make sure the positive wire for the radar is long enough... i know it seems alot but once youve found the right fuse to tap into, just run the wires in the pillars and there you go... i did this when i installed my LED strips near my fog lights....
Old Dec 1, 2011 | 09:01 PM
LtLeary's Avatar
I think I have a pic on my cell phone I took when I wired mine in a year or two ago. I'll take a look and if nothing else, report back on the color/pins I used.
Old Dec 2, 2011 | 05:58 AM
LtLeary's Avatar
Not the best pix, but hopefully it will point you in the right directions
http://forums.maxima.org/album.php?a...ictureid=30440
http://forums.maxima.org/album.php?a...ictureid=30441
Old Dec 16, 2011 | 06:24 AM
wope's Avatar
Thanks for the pics, I appreciate it.
Old Dec 16, 2011 | 09:59 AM
MaximaSE96's Avatar
Maxima Owner
by an add a fuse an use and open fuse
http://www.google.com/products/catal...ed=0CEAQ8wIwAQ
Old Dec 16, 2011 | 06:17 PM
LtLeary's Avatar
No problem..those pix are using invisicord. The pins have been secure and viable for over a year now.
Old May 7, 2020 | 11:11 AM
Jaison Mathai's Avatar
This a long shot, but recently got wire taps and trying to do the same thing. Can you post pics as well? I was trying to do similar to your pics but a bit blurry. Thank you!
JRod28
Feb 4, 2016 11:07 AM
Huttig2009
Sep 25, 2015 03:31 PM
Maxilano
Aug 31, 2015 07:33 PM
Quickgtp
Aug 27, 2015 02:13 PM
BobMax
Aug 19, 2015 04:39 PM
