Review of BC Coilovers and staggered 20's on a '12
Old Jul 13, 2012 | 08:41 AM
  #41
BBmaxi's Avatar
His struts a blown though, so he or you has to buy new strut cartridges?
Originally Posted by rtitan
They will only send the springs, swapping them out is pretty easy. I had the same issue, and it has been a over a year now with no problems and I live in NYC as well!
Old Jul 13, 2012 | 09:17 AM
  #42
rtitan's Avatar
Im pretty sure they will seeing how they did not last a month!
Old Jul 14, 2012 | 12:00 PM
  #43
Whitemaxx's Avatar
Lets hope so! Waiting to hear back from BC...
Old Jul 16, 2012 | 07:26 PM
  #44
Rods03Max619's Avatar
Clean....
Old Jul 16, 2012 | 09:21 PM
  #45
Whitemaxx's Avatar
Clean....
Thanks Rod!
Old Jul 17, 2012 | 01:42 PM
  #46
Nemo7's Avatar
Okay im seeing all this spring rates conversation what is a good spring rate for our car?
im in between KSport and BC
the KSPort offers a
Spring rates front (kg/lbs): 8.7/487
Spring rates rear (kg/lbs): 7.2/403
and i am unsure about BC
are these good spring rates for the Max?
Old Jul 17, 2012 | 02:12 PM
  #47
streetuner's Avatar
the KSPort offers a
I would get BC's rather than Ksport. Better ride imo.
BC standard rate for our cars is 7kg front and rear. They do offer custom rates at your request. But as you read in previous posts, some members had/have 7kg and having issues. ritan ran into that problem but now he has 10kg front/rear and the ride is great!!
Old Jul 17, 2012 | 02:38 PM
  #48
Nemo7's Avatar
My boy Dean has KSports and i do like his set up it is meant more for comfort than handleing he was just not sure what his spring rate is he has not had any blows or anything so im just trying to figure out if these were a good rate for the car
Old Jul 19, 2012 | 11:35 PM
  #49
BBmaxi's Avatar
yes 9k at front is a must.
the ride will still be comfortable with 7k, and probably more comfortable than 9k but you have to be really careful and slow going over speed bumps. If your not careful you will bottom out very easily.
I have never bottomed out while on street or freeway, only by going over speed bumps too fast.
the a35 6 banger needs a 9k at front. No way around it, the sets that sell with 7k are made for 4banger altimas.
Old Jul 19, 2012 | 11:36 PM
  #50
IFuXwiTuZ's Avatar
i really like how u painted the lower grill white real classy imo
Old Jul 19, 2012 | 11:40 PM
  #51
BBmaxi's Avatar
ya the painted lower grille is hot.
Old Jul 20, 2012 | 05:20 AM
  #52
Whitemaxx's Avatar
BC is swapping out the 7ks for 9k. Hassle free. Great customer service. I'm hoping that the issue is only the springs and not the cartridges. We will see in a few days.
Thanks guys but that's actually stock on the '12s.
Old Jul 20, 2012 | 05:41 AM
  #53
PSU09MAXIMA's Avatar
Good To hear did they also reimburse you for the struts?
Old Jul 20, 2012 | 06:38 PM
  #54
Whitemaxx's Avatar
They said they would if I provide them with pictures of the damage. I won't know for sure until I get the new springs put on.
Old Jul 27, 2012 | 12:21 AM
  #55
Whitemaxx's Avatar
Got the 9k springs put on the front today. MUCH better! Strut cartridges are good also so I lucked out there. For anybody looking to run this setup, definitely save time and effort and get the 9k's from the start.
Old Jul 27, 2012 | 06:12 AM
  #56
sounds good man glad to hear
Old Sep 6, 2012 | 12:18 AM
  #57
BBmaxi's Avatar
white max did your struts make a clunking noise ? My front struts are now making clunking noise. I'm trying to figure out if it's my cv boot axle or strut related noise.
Old Sep 7, 2012 | 09:24 AM
  #58
Whitemaxx's Avatar
When do you hear the noise? Going over bumps, turning, etc..
When I adjust the dampening to a more stiffer setting everything feels smooth and tight up front. But after a week or so I start to feel a tapping in the gas and brake pedals going over bumps and the ride gets harsher. I hear minor noises up front associated with these issues. I'm starting to think I need new strut cartridges after all from my first problem.
If the noise is associated with a more uncomfortable ride, my guess is that it's your struts.
Old Sep 7, 2012 | 09:47 AM
  #59
BBmaxi's Avatar
I just double checked mine and fortunately it was the loose end links that was causing the noise. I just tightened the top bolt of the vertical looking piece and it removed the noise.
If your hearing and feeling a tap in the pedals, it could be your loose end links since the end links connect to some bars that go under the car and across the pedal area. you may want to check that out. You need two wrenches to tighten the end link.
Old Sep 7, 2012 | 12:37 PM
  #60
Jbling700's Avatar
BBmaxi I'm hearing a knocking noise and I'm lower on Eibachs. You think it could be my end links too? Also when I go up my driveway and go over small bumps on the road, I can feel my gas pedal having a light tap to it also and it's annoying. Been doing that for over 2 months.
Old Sep 7, 2012 | 01:06 PM
  #61
BBmaxi's Avatar
yes check your endlinks, It could be a loose bottom bar (maybe called sway bars?) that's attached to both sides of the endlinks, and the reason why the sound is coming from the bottom of car and why you can feel it on the pedals.
for me it was the top nut of the endlink. The bottom nut was tight with no problems. The top connector of the end link consists of two nuts. The two nuts sandwich the coilover tab. If you tighten just the outer nut it will keep spinning, so you need to hold the inner nut in place so they tighten up.
they look like this:
Old Sep 7, 2012 | 05:24 PM
  #62
Jbling700's Avatar
Thanks a bunch BBmaxi... I lifted my car up today and it worked!!!! It was loose no more noise I can finally drive in peace and no more cranking up the radio to ignore the noise....
Old Sep 7, 2012 | 08:19 PM
  #63
Dieseldan's Avatar
wow great info BB thanx
Old Sep 8, 2012 | 06:55 AM
  #64
Whitemaxx's Avatar
Great info indeed! I'll have to take a look when I have time.
Old Sep 8, 2012 | 12:00 PM
  #65
BBmaxi's Avatar
you welcome guys! glad I could help.
I'm just glad it wasn't a costly fix.
mclasser
22
Nov 12, 2020 01:58 PM
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
Garrettz459
Sep 28, 2015 02:50 PM
rbaker100
Sep 25, 2015 07:52 PM
