Cigarette Lighter Removal
Old Sep 7, 2012 | 04:32 PM
aiwa101's Avatar
Hey everyone so one way or another a nickel fell into my cigarette lighter(the one right behind the cup holders, not the armrest) and somehow it is wedged under the lip at the bottom of the of the cigarette lighter. I tried everything to get it out. I tried using tweezers, a angled pick, tiny flat head, etc. Nothing is working so i want to try to take the whole assembly out, but am unsure how to do it. Does anybody know how? Thanks
Old Sep 7, 2012 | 10:55 PM
eepowers's Avatar
Try using a small pointed knife to flip it on is side, and out with it. I had a penny fall in mine a month ago. I got it out, but not before lowing the 20amp fuse that goes with it.
Old Sep 7, 2012 | 11:09 PM
morteljc's Avatar
use a wooden stick and put a chewed bubble gum, rice, or something sticky... maybe it would get it out...
Old Sep 8, 2012 | 07:45 AM
eepowers's Avatar
Or use a piece of tape, sticky side out, wrapped around a pen or pencil.
Old Sep 8, 2012 | 09:40 AM
aiwa101's Avatar
I tried everything the nickel seems to be wider then the cigarette lighter so it's really stuck . I just need to figure out how to take the assembly out.
Old Sep 8, 2012 | 09:50 AM
Compusmurf's Avatar
Love my '09
Can't be wider if it dropped in. Maybe a pencil, put a drop of superglue on the eraser and stick it to the coin. Let it dry and it'll give you a bit more leverage?
Old Sep 8, 2012 | 09:57 AM
aiwa101's Avatar
i tried the superglue trick too there is a lip at the bottom of the lighter and it is under the lip so when i try to pull one side up the other side just hits the lip...
Old Sep 8, 2012 | 09:53 PM
Shipwreck's Avatar
You might have to dismantle the center console to get the lighter socket out. Try and check out the repair manual on the nicoclub website.
Old Sep 9, 2012 | 01:08 AM
jommbi's Avatar
I know you asked for assembly instructions but...Sharpie magic marker or thick wood dowel and some 3m double sided tape.
If that fails you can always go to the dealer and explain why you have a nickel, a pencil, bubble gum, 3m tape, wood dowel, and a screw driver jammed into your cigarette lighter. They may take pity on you.
Sorry about the joke
Old Sep 10, 2012 | 03:35 PM
zoemayne's Avatar
let it be... you have another one right in the arm rest.. you shouldnt take it apart just keep trying to take it out with different methods.. maybe buy a simple tool.. melt the nickle a little? taking the whole thing apart is overkill too much time.. but hey i dont know what your times worth.
Old Sep 10, 2012 | 04:02 PM
20_Maxima_10's Avatar
You're making this alot harder than necessary......go to an autoparts store and buy a cigarette lighter removal tool. done.
Old Sep 12, 2012 | 03:43 PM
aiwa101's Avatar
i never knew those even existed....imma go check that out tommorow thanks!
Old Apr 2, 2013 | 06:50 AM
LtLeary's Avatar
Did it work? Easy to remove and replace?
Old May 12, 2019 | 10:57 AM
harvey02's Avatar
Yes, I know this thread is from a few years ago, but I too recently had this problem and found an easy way to remove the coin.
I used a pair of hose pliers I had previouslybought cheap at harbor freight, to grip the sides of the socket. I moved it from side to side and then the socket popped out of the console. There was then small opening on the bottom of the socket where I was able to insert a flathead screwdriver to tilt the lodged coin upward. I then used a pair of needlenose pliers to pull the coin out.
Now I have a working socket
Old Jul 13, 2019 | 09:57 PM
Chris Louis's Avatar
I had some pennies stuck in mine. One time I was vacuuming my Maxima at a local car wash and stuck the hose in that compartment. The vacuum was strong enough to suck the coins right out of the cigarette lighter.
Now I make sure I keep that cap closed when I'm not using it.
Maxima2009
22
Apr 27, 2016 12:41 PM
Hans
Feb 16, 2014 01:46 PM
Litowcas
Apr 3, 2006 09:18 AM
lyonsd
May 22, 2004 02:24 PM
blackmaxima
Sep 22, 2001 10:37 AM
