2012 HID Install
Old Oct 2, 2012 | 11:42 AM
1ll35t's Avatar
2012 HID Install
Can anyone point me to a good DIY thread on HID install for the 2009 and up Max? I have a 2012 and had 2011. On my 11' I went through the fender wells and it was a real *****. Wondering if there is any other way besides that way or removing the bumper? Thanks in advance.
Old Oct 2, 2012 | 11:45 AM
Install will be the same on your '12.
Old Oct 2, 2012 | 01:27 PM
Jbling700's Avatar
Here's where I placed my ballast. Easy access and when something blows, easy replacement. I circled the area where I placed it. I used to have it behind the bumper until I realized this route will be a pain in the future.
Old Oct 2, 2012 | 01:46 PM
1ll35t's Avatar
Jbling -
Thanks for the image. That's a good idea for sure. Actually attempted that my first time but failed because wasn't enough slack from the ballasts. Did you still have to remove wheels and fender walls to change bulbs or?
Sent from my iPhone using MaximaOrg
Old Oct 2, 2012 | 02:30 PM
Jbling700's Avatar
Originally Posted by 1ll35t
Jbling -
Very very very heavy duty 3M tape is holding both of my ballast and no I don't have to remove wheels to change the bulbs since I did this. I just turn my tires left or right, remove one clip each side, slightly bend the plastic, slip my hands inside, then twist and pull the bulb towards me. Removing the wheels is too much work for me. I go the easy way in . That's how I roll If your lowered on Eibach springs, it's going to be kind of tight. On stock springs it's easy and you have room to work and play around. If your slammed, then it's going to be a challenge.
Old Oct 2, 2012 | 02:47 PM
1ll35t's Avatar
Someone told me to do this last install on my 11. I ended up removing the wheels, fender walls and it was still a pain. Mostly because I mounted the ballasts 100% in the ***** lol. They held up until I got rid of the car though but I won't do it again. Easy squeezy burns when you peezy. Gonna try it this way next time and see though.
Car is not lowered (yet). Did mount the ballasts then just drop the cables down in the fenders?
Old Oct 2, 2012 | 03:38 PM
Jbling700's Avatar
Mounted the ballast then ran the two wires through the square hole then connected the wires. Make sure the 3M is heavy duty and heat resistant since our engine bay loves to generate heat.
Old Oct 2, 2012 | 04:00 PM
1ll35t's Avatar
Gonna try this the "easy way" when it's dry out!
Old Oct 2, 2012 | 05:05 PM
1ll35t's Avatar
Thanks for the info btw
Old Oct 2, 2012 | 05:16 PM
Jbling700's Avatar
LOL and no problem man... glad I can help a bit...
Old Oct 2, 2012 | 08:45 PM
Jarohnimo's Avatar
This seems like a pain in the @ss to do... Lol someone should post a video of this for the max.on Utube
Old Oct 2, 2012 | 08:59 PM
1ll35t's Avatar
I'll probably do a write up on here or vid on YouTube
Old Oct 2, 2012 | 10:01 PM
zumoney's Avatar
Talking
i'll probably do a write up on here or vid on youtube
sent from my iphone using maximaorg
please do!!!!
Old Oct 2, 2012 | 10:04 PM
zumoney's Avatar
[/QUOTE]
I love your grille, front lips and LED strip lights on your bumper. Where did you get them? Did you install them yourself? If you did, would you mind sharing how you did that? They look awesome!
Old Oct 3, 2012 | 07:39 AM
Jbling700's Avatar
Thanks man. The grill I did myself. There's a DIY here I posted. Check it out. The front lip you can get from Stillen.com or buy from another 7th gen owner whose parting out their Max like I did. The leds you can get from www.ijdmtoy.com. I got the slim design but it wasn't bright enough for me so I modified it by buying Vled individual leds. I originally wanted Vled DRLs like Ghozt but I didn't feel like modifying the plastic anymore and got lazy. LOL it's brighter IMO and it's a 5K look.
9aj9
Apr 5, 2020 12:11 AM
MaxLife17
Jun 27, 2019 01:37 PM
Vistance
Sep 17, 2015 05:17 AM
popdedop
Sep 11, 2015 11:17 AM
MaxLife17
Sep 8, 2015 02:36 PM
