window problems?
Old May 1, 2013 | 09:12 PM
bigjoe's Avatar
window problems?
hey whatsup guys, was wondering if anyone had any problems with the automatic windows? i had a problem on my drivers side a while back and they re programmed it, i now have the problem on my passanger side. its automatic on the way down but not on the way up. any ideas? when i try to use the hold for 10 sec up and 10 sec down the window just gets stuck. any ideas? if i need to re program the window switch how do i do? thanks
Old May 2, 2013 | 09:44 AM
Hawks102089's Avatar
Have you disconnected the battery? When I did my auto up quit working.
I believe I had to roll the window down, the roll it up but keep holding the button for about 10 seconds after then it should work. You might have to do it a few times but it worked for me.
Old May 2, 2013 | 11:33 AM
bigjoe's Avatar
Yeah, that doesn't work. It gets the window stuck and then I have to wait a few seconds for it to work
Old May 2, 2013 | 02:26 PM
brandon7gen's Avatar
Ignition has to be switched to ON for it to work.
Old May 6, 2013 | 08:06 AM
bigjoe's Avatar
let me guess you graduated in the top 10% in college you moron
Old May 6, 2013 | 08:44 AM
Seriously? Some people forget the simplest things, he's just trying to help. I hope your auto-up never works again, moron
Old May 6, 2013 | 09:21 AM
WiSeGuY187's Avatar
Easiest way to reprogram is hold up on button for 10 secs then hold down for 10 sec and then ull have ur auto windows back
Old May 6, 2013 | 01:05 PM
Mario66's Avatar
Funny enough this just happened to me as well.
I had to swap out my battery and when I put it in neither window did the auto roll down anymore. So I reprogrammed my drivers side by holding it up for ten seconds and the drivers side works fine. But when I went to do the same thing to the passenger side the window just gets stuck for a few seconds and does not reprogram. Very weird. Any thoughts?
Old May 7, 2013 | 02:35 PM
Mario66's Avatar
Bump.
Anyone?
Old May 7, 2013 | 06:06 PM
Lemonhawk's Avatar
With out using the auto up or down switch position, put the window down, then hold in the auto down position. Then with out using the auto up roll the window up and then hold the switch in the auto up. It is in the manual.
Old May 8, 2013 | 10:05 AM
Mario66's Avatar
Ill try that once the Biblical rainfall were getting here in NY ends. Dont want to take a chance of the window not rolling up again.
pears
Sep 18, 2015 05:25 AM
thenewguyy
Sep 12, 2015 11:12 AM
markevans999
Sep 10, 2015 04:29 PM
ef9
Sep 5, 2015 11:18 PM
