Insdie trunk release
Old Dec 30, 2013 | 09:42 AM
LarryS's Avatar
My trunk release has stopped functioning. The keyfob remote and the decklid button both function fine, but the cockpit release has no responce. Any ideas?
Old Dec 30, 2013 | 09:48 AM
silver7thgen's Avatar
Check your glove box there's a switch inside.
Old Dec 30, 2013 | 06:37 PM
Akiyukio's Avatar
I have a feeling that this solution is invalid.
Unless I am misunderstanding the purpose and how that switch works, then here is my reason:
When using valet parking, valuables and other items that may not want to be seen and easily accessible are to placed in the trunk and the switch moved to "OFF". After turning off the switch, the glove box should now be locked with the physical key so that trunk access is completely inhibited until proper access is gained and the switch is reactivated. Otherwise, anyone could still use the intelligent key (key button and trunk button) to open the trunk rendering the glove box switch useless. Thus, I have a feeling that something else is wrong here and not the switch in the glove box.
Old Dec 30, 2013 | 07:10 PM
Richard66's Avatar
You are correct in that when the switch in the glove box is turned off then the trunk lid openers, keyfob, dashboard switch and trunk lid stitch are all disabled, thereby locking the trunk from any access. Since you can access the trunk lid from the fob and the trunk lid with the glove box switch on then the switch on the dash board is probably defective.
Old Jan 27, 2017 | 01:50 PM
Amandia Cabbil-Hewitt's Avatar
did you get this fix I am having the same problem my switch is on but nothing but emergency trunk release opens my trunk
Old May 2, 2018 | 07:08 AM
10aCMike's Avatar
What was the solution to this problem?
REDinLV
Aug 15, 2024 12:30 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
05RLS2
Sep 27, 2015 09:24 PM
Mikes14Max
Advance Paint and Body Work
Sep 14, 2015 05:28 PM
rbaker100
Sep 6, 2015 02:46 PM
