Replacement Cigarette Lighter outlet
Old Jan 18, 2014 | 10:00 PM
09NissanMaxima's Avatar
Hey everyone, i tried looking for a replacement cigarette outlet and i cant seem to find an oem one. I found a couple that say minor modification required which i dont want to do. I looked on nissans oem website and it says lighter protector so im assuming that is just the ring around it. Does anyone know where to get a factory oem one?
Thanks!
Old Jan 18, 2014 | 10:10 PM
i found this, and in one part it says power outlet and the next it says power outlet protector???
http://www.group1autoparts.com/oem-p...et/25336-9b92a
Old Jan 19, 2014 | 04:05 AM
koreanthunda's Avatar
Match your part numbers . That's it though but always cross ref you numbers to be sure if they give you the numbers.
Old Jan 19, 2014 | 08:03 AM
Akiyukio's Avatar
Finding this was a bit more difficult than I expected...
http://www.courtesyparts.com/maxima-...8342_8346.html
Try this?
http://www.courtesyparts.com/26029m-...ml?cPath=8300&
or this?
http://www.courtesyparts.com/25336ma...-p-606854.html
First one looks like it is for the one closer to the gear shift, and the second one appears to be for the one inside the arm-rest area.
Both pictures and links are the best I can do, the diagrams are not clear enough where that socket goes.
Old Jan 19, 2014 | 05:15 PM
Try this?
or this?
Wait now im confused. Is it the part i listed :
or this one says its for a headlight from the diagram)
Old Jan 21, 2014 | 04:31 PM
Akiyukio's Avatar
Hmm.... I guess it is best to go with plan B:
Try the parts department at your local dealer, and check out the prices as well as ask for the part number.
Worst case, just say that you'll consider getting it sometime or some other excuse.
PH98I30
29
Feb 10, 2025 12:03 PM
captchaos
Mar 15, 2016 12:18 PM
dvcamp
Sep 18, 2015 10:17 AM
dcam0326
Sep 8, 2015 11:02 PM
Maxima30
Sep 7, 2015 06:13 PM
