Need help fast
Old Jan 20, 2014 | 08:32 AM
kneehead's Avatar
Need help fast
Long story short..I pressed down on my E brake to test something out and did it a few times..I press down all the way to release and it works but for some reason seems like my rear brake is still on.When I put it in drive it goes but still feels like brakes are on.When I'm accelerating it vibrates in the back and brakes squeak a bit...Any advice..I put new pads about 6 months ago and no brake light on the dash..only when ebrake is engaged..I never had this issue before..Thanks
Old Jan 20, 2014 | 12:45 PM
koreanthunda's Avatar
You need to adjust your rear brakes or cable if it is an option I did that on a Subaru years ago . Or spray your cable inside
Old Jan 20, 2014 | 01:22 PM
13Maximasv's Avatar
Could be a seized rear caliper, get it checked fast or that rotor(s) will be shot
Old Jan 20, 2014 | 02:34 PM
trailer54's Avatar
Both of those are a great start to look^^^
Old Jan 21, 2014 | 05:27 AM
vball_max's Avatar
could be the caliper. Take a stick or something and give a push on the e-brake lever on the caliper. It might just be stuck and it will pop back out once you push on it. If thats it, just spray some WD-40 on the e-brake mechanism on the caliper to keep it lubricated.
Old Jan 22, 2014 | 09:05 AM
maxud's Avatar
e-brake on the 7th gen Maxima has nothing to do with calipers. Its a drum inside disk setup. There are brake shoes inside rear rotor.
Raise the rear of the car.
Make sure e-brake is not engaged.
Try to spin each rear tire.
Then take it from there.
To get to the e-brake shoes, you need to remove the wheel, caliper, caliper bracket and the rotor.
If you never used your e-brake before, your e-brake cable could have gotten stuck. You have to trace it to figure out
the problem. Each rear wheel will have a separate cable going to it.
good luck,
Max
Old Jan 22, 2014 | 10:01 AM
vball_max's Avatar
Oops...my bad. Sorry. I assumed it was similar to my 5th gen.
Old Jan 22, 2014 | 10:04 AM
maxud's Avatar
yeah, I was gonna say, my 4th gen had the e-brake on caliper setup, but I don't know which gen switched over.
lrb6805
Sep 30, 2015 08:12 AM
msellas
Sep 23, 2015 09:16 PM
220k+ A32
Sep 23, 2015 03:38 PM
pears
Sep 18, 2015 05:25 AM
