Need help with clip to fasten wheel hub moulding
Old Feb 15, 2014 | 08:42 PM
jrodman's Avatar
Hello to all. I need help with figuring out what clip/fastener I need to fix the following issue: the moulding/panel inside the front right wheel hub is supposed to be secured to the undercarriage of the Maxima, in the area below the engine, by a rubber piece that is connected to the moulding on one end and the undercarriage of the car on the other end. In my Maxima's case, the rubber piece is properly attached to the moulding. But, the clip/fastener that the rubber piece is supposed to attach to under the engine compartment on the undercarriage of the Maxima has fallen out of the hole. Now, the rubber piece is hanging and the moulding is not secured to the undercarriage of the car the way it is supposed to be. If anyone could send me a link to purchase the OEM clip/fastener to fasten the rubber down to the undercarriage I would be forever grateful. This is driving me nuts! Thank you to all for taking the time to help me out. FYI--my Maxima is a 2009 SV.
Old Feb 15, 2014 | 09:29 PM
dr_2010SV's Avatar
It's a simple plastic (expanding type) fastener. They sell these at auto parts stores everywhere and in assorted sizes. Some even come with a Phillips type head to screw-in.
You could go to the dealership but they are on the spendy side.
Old Feb 15, 2014 | 09:32 PM
jrodman's Avatar
I went to Advanced Auto Parts last week and they did not seem to have what I needed. Also, the hole that the fastener goes into is not ribbed at all, it is completely open inside. Do you have a part number for me so I can order the right fastener? Or could you send me a link to a fastener that you think would do it? Thanks so much for your help.
Old Feb 15, 2014 | 09:54 PM
dr_2010SV's Avatar
This is what they in effect are, these are 8mm.
I'm not sure of the hole size, but you should be able to figure that out on your own unless someone here knows off-hand?
It's not rocket science.
Amazon.com: Nissan or Universal Fender Push Type Retainers Clips (Hole Size 8MM, Head Diameter 20MM, Stem Length 9MM) - Replace # 01553-09321 - Package of 12: Automotive Amazon.com: Nissan or Universal Fender Push Type Retainers Clips (Hole Size 8MM, Head Diameter 20MM, Stem Length 9MM) - Replace # 01553-09321 - Package of 12: Automotive
Old Feb 15, 2014 | 11:29 PM
Grego214's Avatar
They sell these little ****s on ebay for cheap. Search for Nissan clips.
Old Feb 16, 2014 | 07:57 AM
Select the XB35 bulbs and thank me later.
http://www.theretrofitsource.com/hid...ystem-h11.html
londonflu
40
Sep 25, 2015 09:11 AM
Johnny9595
Sep 16, 2015 07:20 PM
dcam0326
Sep 8, 2015 11:02 PM
maximusrising
Sep 2, 2015 09:55 AM
