Power steering going out?
I have recently noticed that when I am idling, 600RPM or lower, it's very, very hard to turn my steering wheel. However, if I put the car in park and its at 600RPM and I give it some gas, they steering wheel turns perfectly. Any ideas why? I'm baffled.
There is a thread on here about a bunch of our power steering pumps going out, me included. So if yours is going out, it's no surprise to me. Unfortunately if this is the case, the dealers have been having a shortage of them
Get a rebuild kit from Rockauto.com it's easy not much to it...Hardest part is taking it off and reinstalling it! Disassembly and reasembly is easy as hell.
Last resort - check lug nut tightness....dunno - grasping at straws on that one.
Sounds Like a power steering pump issue to me since the low speed & high Speed behavoir are a different feel and boost level! Swap it with a Good used unit or rebuild yours.....Sounds like the pressure relieve valve is stuck open and since these really don't have a true filteration system it's possible to have some debris in your system or just dirty a$$ fluid (Dextron 3)....causing your pump to bypass most of your pressure....
Coming from an '02 Honda Accord (original owner), I had zero issues until the car was about 10 years old.
Follow up. Got my car back Feb 26. They had changed my power steering unit and now my steering is fine but I'm hearing a pop or knock sound coming from the front passenger side of the console. I havent found the exact location of the sound and its intermittent but it may be the right front brake caliper. Any suggestions?
Sorry, the sound has occurred when leaving a stop sign or occasionally when accelerating and then taking my foot off the gas, there's like a "pop" or "knock" sound.
Power steering pump
Pump, injector
Gasket
Oil A/T 1L
2DR9A clip
The hourly rate for labor here in Canada was listed at $99.95
Due to the fact that its warrantied I paid zero. I have to return there this week for something else, so I will inquire as to the actual cost for parts and labor time for you.
As to the cost, they couldnt tell me exactly but the service guy I spoke to said it was easily a $500 job. But...the labor was $99.95/ hr for about 4 Hrs so all the parts I listed before were a total of about $100.
Hope this helps.
lowpost99
Oct 26, 2025 06:53 PM
rbarnes
Dec 31, 2015 06:29 PM
fastcarny
Oct 12, 2015 07:06 AM
