Are my Springs suppose to....
Old May 10, 2014 | 02:47 PM
GNCMaxima's Avatar
I recently got my rear control arms put, in at a shop, (which they pretty much messed up) and I noticed just this week that one of my spring looks different compared to the other spring?
I dont have the tools to get under the car to do it myself, but I thought I could get some feedback if im wrong or not?
I parked the car on a flat surface with nothing heavy on either side so you tell me if its normal or not!
Rear Right Spring
Rear Left Spring
Old May 10, 2014 | 03:00 PM
MaximaDrvr's Avatar
Something isn't correct.
Old May 10, 2014 | 03:06 PM
Fakie J Farkerton's Avatar
Back to the shop and then never go there again.
Old May 10, 2014 | 03:07 PM
GNCMaxima's Avatar
Yeah I don't want to go there period and with my work I can't make it on their schedule. Which side looks wrong?
Old May 10, 2014 | 03:10 PM
tonydatigeryo's Avatar
Correct me if I'm wrong, but the deadcoils are usually on top, right?
Old May 10, 2014 | 03:17 PM
GNCMaxima's Avatar
Dead coils? Lol English?
From the DIY? But can someone take a picture of there rear springs for me?
http://vqpower.com/images/howto/09eibach/IMAG0480.jpg
Old May 10, 2014 | 11:28 PM
The coils that don't contribute to the actual spring effect; they look like a compressed slinky so to speak
Old May 11, 2014 | 07:20 AM
Maximam's Avatar
Dead coils should sit on the stationary side (top) reducing "un-sprung" weight. Left spring is incorrect.
Old May 11, 2014 | 07:24 AM
dr_2010SV's Avatar
^ Correct the dead coils are on the top and springs are often designed this way, another term used is "coil bind".
Judging from your picture something isn't quite right.
It's been a couple years now since I installed my Eibachs but I thought I saw a couple coils together (on top) which is normal in some applications. Sometimes you see rubber around some select coils where they can make contact.
Old May 11, 2014 | 08:25 PM
Racerbox77's Avatar
Dead coils go on top. And make sure they re-align your car after they swap the spring. Trust me it will throw off your alignment. Idiots.... That sucks bud.
Old May 11, 2014 | 09:41 PM
GNCMaxima's Avatar
Thanks. I'll try not to rage and be calm
Old May 11, 2014 | 09:43 PM
trailer54's Avatar
Morons; yes, you'll have to fix that!
Old May 12, 2014 | 07:39 AM
GNCMaxima's Avatar
They said having the spring upside down won't throw off the alignment.... they will fix the spring but no alignment
Old May 12, 2014 | 12:21 PM
Racerbox77's Avatar
That is false. In order to get the spring out you have to undo the spring bucket arm. When you bolt it back up it won't be the same. I guarantee it. It happened to my car.
Old May 12, 2014 | 03:04 PM
GNCMaxima's Avatar
Now they said they never touched the spring because it wasn't needed for the control arm install. . . I'm so confused
Old May 12, 2014 | 05:50 PM
dr_2010SV's Avatar
Normally that statement is true....as long as they aren't lying to you!
It's obvious (from your pictures) that at sometime in the past someone has had a wrench on the bolts for both rear lower links. The rust on the RH side bolt could indicate it was before these knuckle-heads touched your car. Who the hell knows?
P.S. The 2010 FSM RSU-9 illustration identifies these parts as #14 rear lower links. Calling them "spring bucket arms" as Racerbox does is actually a more descriptive term for the sake of these forum discussions.
Old May 13, 2014 | 01:24 PM
maxud's Avatar
To me it looks like your rear right spring has an insulator (rubber sleeve) that came off the spring and wedged itself between the top two turns of the spring. What looks like an extra coil turn must be the insulator. Just put it back on the spring in the same spot as your other side. Problem solved.
MaxLvr21
Oct 17, 2015 12:11 PM
220k+ A32
25
Oct 3, 2015 09:09 PM
maxima297
Sep 30, 2015 03:32 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
