Morimoto XB Strips
Old Jun 1, 2014 | 04:36 PM
maxipad2011's Avatar
Cool Morimoto XB Strips
Does anyone have these? If so, what's the width from top to bottom on them? Thinking of mounting (sticking them) to my already mounted brake duct DRLs that are giving me fits and am hoping that these give a wide enough light to fill that slot:
http://www.theretrofitsource.com/mor...l#.U4u4b_ldVQE
Old Jun 1, 2014 | 04:51 PM
escblads's Avatar
They are 70mm wide.
You'll also need to know that these weren't designed to be waterproof, so you'll need something to cover them up. Also the LEDs are mounted on a slightly bendable sheet of metal and they do get quite warm when running, so finding an adhesive that could hold with the heat generated by the LEDs and the sun could be interesting. They are best used for applications inside a headlight or interior of the car.
EDIT: Plus a pic showing the brightness compared to my halos, they're about the same, the strips are just angled and have nothing to reflect off of like the halos. Overall pretty visible in direct sunlight, but we're not talking Audi levels of brightness lol.
http://imgur.com/vIMyXDa
Old Jun 1, 2014 | 05:47 PM
Originally Posted by escblads
They are 70mm wide. You'll also need to know that these weren't designed to be waterproof, so you'll need something to cover them up. Also the LEDs are mounted on a slightly bendable sheet of metal and they do get quite warm when running, so finding an adhesive that could hold with the heat generated by the LEDs and the sun could be interesting. They are best used for applications inside a headlight or interior of the car.
Got it! Thank you....
So would the 5LED DRL option be better in this case?
Old Jun 1, 2014 | 06:47 PM
Daaavid's Avatar
We're still talking about Morimoto right, specifically the X.DRL?
I was looking at the X.DRL, and looked up a couple of install pics on HiDplanet. I think they stick out like a sore thumb, especially with the magnified yellow diodes. You're still going to need a dimmer module of some sort, but they are ridiculously bright and 5000k in temperature.
Old Jun 1, 2014 | 06:48 PM
Mlang2000's Avatar
I tried the adhesive strip kind a while back and they didn't last 6 months.
I then tried this style:
and only got another 6 months (Winter seemed to destoy them).
I'm looking at the Morimoto X.DRL but I think it's too long. We only have about 5.5 inches in these brake ducts and they're about 6.3. I'm starting to think reliable LED's that fit in there isn't an option.
Has anyone tried the individual pod style LED's in the honeycomb holes?
Old Jun 1, 2014 | 06:55 PM
Originally Posted by Daaavid
We're still talking about Morimoto right, specifically the X.DRL? I was looking at the X.DRL, and looked up a couple of install pics on HiDplanet. I think they stick out like a sore thumb, especially with the magnified yellow diodes. You're still going to need a dimmer module of some sort, but they are ridiculously bright and 5000k in temperature.
We are yes and I agree with that which is why I decided against them in the first place....but here I am again....
I also saw on the reviews how bright they were...also an obstacle unless I wire them to turn off at night since I also have dual halos.
Old Jun 1, 2014 | 06:57 PM
Originally Posted by Mlang2000
I tried the adhesive strip kind a while back and they didn't last 6 months. I then tried this style: and only got another 6 months (Winter seemed to destoy them). I'm looking at the Morimoto X.DRL but I think it's too long. We only have about 5.5 inches in these brake ducts and they're about 6.3. I'm starting to think reliable LED's that fit in there isn't an option. Has anyone tried the individual pod style LED's in the honeycomb holes?
The ones I currently have in we're already a bit longer as well so these Morimotos should fit in my case. I noticed they are on backorder too....
Old Jun 2, 2014 | 06:54 AM
Ghozt's Avatar
yea I was gonna say the XB LED strips aren't waterproof so they're meant for inside the car or inside a housing.
Old Jun 2, 2014 | 07:43 AM
Propa Teknique's Avatar
I had seen some lights before on the GTR Lighting website and I bookmarked it. What do you guys think of these? I'm assuming they are waterproof since they are actual DRL's.
What I would like to know is if they would fit in our brake ducts?
Universal DRL from GTR Lighting
Old Jun 2, 2014 | 10:38 AM
Mlang2000's Avatar
At 5.75" Long, it might fit with some alteration of the duct. I wish the ducts were easily replaceable instead of being molded in. Have you seen any reviews of these? I nominate you to buy them and report back.
Old Jun 2, 2014 | 08:09 PM
Mlang2000's Avatar
I'm wondering if the LEDayFlex DRL bulbs will work in the existing duct openings without drilling.
Has anyone had any experience with these?
Maybe something like this?
Old Jun 3, 2014 | 08:40 AM
I only want to be nominated for an Oscar. I haven't seen any reviews of these anywhere but they seem to be decent considering the really cheaply made ones I saw on eBay. I do want to buy them but my issue is I have NO IDEA ABOUT WIRING or how to cut the brake duct to make it fit. I do remember seeing someone's ride, it may have been Ghozt, who literally cut the lights on each end and then applied silicone to waterproof them before fitting them into the middle part of the duct.
Old Jun 3, 2014 | 08:48 AM
Mlang2000's Avatar
Yep... http://forums.maxima.org/8733658-post17.html
Old Jun 3, 2014 | 09:01 AM
Since you're so good with finding and providing information, I nominate YOU to buy them and apply them.
Old Jun 3, 2014 | 09:11 AM
Mlang2000's Avatar
I'm only going to take this on if I decide to keep it. So don't wait on me.
The thought of permanently hacking up the duct only to have another set of lights burn out sucks. Even a bumper cover in rough shape is $300 if a new set of ducts needs to be epoxy'd back in place.
Old Jun 3, 2014 | 09:46 AM
Since they are LED's they should last a pretty long while right? I don't plan on keeping them forever especially since I MAY trade up to the 8th gen after the first model year comes and goes.
No harm can come from trimming the brake ducts though right? I mean there is nothing behind them right?
Old Jun 3, 2014 | 10:18 AM
Mlang2000's Avatar
Most of these aftermarket LED kits seem to have short lifespans and even shorter warranties. There's nothing behind the ducts, but once you cut into them, there's no going back. I really wish the ducts were a separate replaceable part.
Old Jun 3, 2014 | 10:41 AM
I think I just may buy these strips after doing a little more research and I'll have to measure the duct and the lights once I get them. Of course, I'll have to find someone to add them to my Max as I'm not blessed in the wiring area.
Old Jun 3, 2014 | 11:01 AM
Mlang2000's Avatar
The wiring is the easiest part. You can ground them anywhere under the hood and I tapped into a fuse that fed power to the lights only when the engine was running.
Old Jun 3, 2014 | 03:50 PM
funnyman82's Avatar
Many people on the Facebook page have installed the xdrl without issues. I personally have something similar to the individual bulbs posted above and they work great as well
Old Jun 3, 2014 | 04:05 PM
Mlang2000's Avatar
Which Facebook page are you talking about?
What brand individual bulbs are you using and for how long?
Thanks!
Old Jun 3, 2014 | 04:47 PM
funnyman82's Avatar
Search for 2009-2013 Nissan maxima 7thgen a35.. Very good page
I'm using the eagle eye ones off ebay
Old Jun 3, 2014 | 05:56 PM
Mlang2000's Avatar
Thanks...I used to belong to that group but must have backed out because I had to request to join again. I'd love to see some close up pics and details of brake duct LED's.
Old Jun 3, 2014 | 08:01 PM
I ordered the Phillips 4 DRLs since I've heard great things on here about them and they will be a direct fit in the slot I've created for the current ones!
Old Jun 4, 2014 | 06:46 AM
Do you realize that that was Klingon you just wrote?
What does that mean?
Old Jun 4, 2014 | 10:04 AM
Mlang2000's Avatar
In that case, yeah...have someone do it for you.
I found some pics and the Morimoto X.DRL seems to squeeze in there. I'm thinking the tabs on that front plate could be filed down a bit for an even better fit.
Old Jun 4, 2014 | 01:06 PM
That looks really sharp and clean. I'm still a fan of the square shaped ones that Ghozt has on his car. It just makes the look more complete. Where can you find these rounded ones at? Are they all together or are they separate pieces placed together?
Old Jun 4, 2014 | 01:08 PM
Mlang2000's Avatar
All together ... http://www.theretrofitsource.com/led...l#.U4uY4iimVHo
Mlang2000's Avatar
And I like that it has a 5 year warranty!
Old Jun 4, 2014 | 01:09 PM
http://www.theretrofitsource.com/led...l#.U4989ym9LCQ
Old Jun 6, 2014 | 09:38 AM
These just came in and I'm realizing it will take all of 10 minutes to install these! My prior set I cut the brake duct and set them flush with the duct....not the front of the car so after a coat of paint over the old lights these will serve as a perfect mounting surface for the Phillips 4s!
Old Jun 6, 2014 | 09:48 AM
Mlang2000's Avatar
I'd love to see the duct cut out before & after install if possible.
Old Jun 6, 2014 | 10:11 AM
No problem!
I'll snap a shot of them as they are now with the current lights mounted and then after the Phillips are in and on.
Old Jun 6, 2014 | 10:18 AM
Mlang2000's Avatar
No problem!
And with nothing installed if you could please. I'm interested in how much "destruction" needs to be done to the duct itself.
Thanks!
Old Jun 6, 2014 | 10:24 AM
And with nothing installed if you could please. I'm interested in how much "destruction" needs to be done to the duct itself. Thanks!
I actually won't be pulling them back out since they are held in tightly with silicone but to give you an idea I cut the "chunk" that protrudes out from the middle between all of the mesh. I will still get some pics the best I can!
Old Jun 6, 2014 | 10:33 AM
Mlang2000's Avatar
OK, thanks.
trsandrew
Apr 8, 2016 06:45 PM
rbarnes
Dec 31, 2015 06:29 PM
trsandrew
Oct 25, 2015 02:47 PM
RealityCheck
Oct 2, 2015 06:34 PM
maxima297
Sep 24, 2015 08:57 PM
