Just bought a 2012 Maxima
Old Nov 8, 2014 | 06:38 AM
andremike's Avatar
So I just bought a 2012 Nissan Maxima SV it has 40K miles
I would like to know what things I should do to it to re-condition the car. I have read about you people going a long time with Brakes, but I can tell something is grinding already. Based on what I read here, its probably the rear brakes.
I changed the air filter
will change the cabin filter
oil/change
Should I get the brake fluid changed?
What else?
Should I put some seafoam in the gas tank?
I buffed and polished/waxed the car and its like brand new.
I did notice the slight rock in the seat, I'm wondering if the Nissan extended warranty "gold" will cover it.
Old Nov 8, 2014 | 07:21 AM
BIGIRISHSTL's Avatar
Congrats. Sounds like you've got all the basics covered. It would depend on previous owner car and maintenance. If your rear brakes are going I would be surprised at 40k.
Old Nov 8, 2014 | 07:37 AM
andremike's Avatar
Well something is grinding in the brakes. The previous owner must of been very hard on them. I honestly don't think he took the greatest care of it. I think the air filter was original. It was so dirty. I would bet he used 87 in the gas tank. I'll have to start using premiuim.
I also read the rears wear before the front's. That's how my Murano was.
I guess I will need to take the wheel off and look.
Old Nov 8, 2014 | 11:53 AM
Daaavid's Avatar
Did you say the seat was rocking? Which seat is rocking? If it is the driver seat, then that should be covered under warranty as it is a common issue with the driver seat coming loose off of its track. I haven't had it happen to me, 2014 with 5k miles, but other members have reported it.
Old Nov 8, 2014 | 04:43 PM
andremike's Avatar
Yes its the drivers seat. well hopefully the "gold" extended warranty will cover the seat.
I looked at the brakes. the front are fine, but the rear is definitely worn,
I replaced the cabin filter and what a pain..
Old Nov 8, 2014 | 05:10 PM
13Maximasv's Avatar
oil/change
Check to see if a rear caliper is sticking. I seem to remember seats not being covered under the extended warranties but I can't say for sure, try searching the forum for posts on the seat rocking issue.
Here is a video on replacing the in cabin filter
http://nissanhelp.com/diy/maxima/pro...dure_video.php
I ran my 1999 Infiniti I30 on 87 octane for 200K miles and it was still going fine when I sold it.
Old Nov 9, 2014 | 04:44 PM
Maxgig's Avatar
Take it to the dealer and get the seat fixed. I had the infamous rocking seat in my 2010 Murano and my 2010 Maxima, both were fixed under warranty. They had to do the Maxima twice because the "fix" caused the seat to hop forward instead of glide.
Old Nov 14, 2014 | 10:25 AM
andremike's Avatar
Rear brakes
Getting ready to my rear brakes this weekend. i have only done rear brakes one other time.. Anything I should be aware of on these cars?
Old Nov 17, 2014 | 10:56 AM
andremike's Avatar
Well I did the rear brakes... Pretty easy. The bottom bolt to the caliper was difficult to get due to the trailing arm being in the way. I was able to get it out by removing the bottom bolt that holds the caliper on, then loosening the top bolt and swing the caliper up. Then I was able to get my socket on the bolt. I didn't have a closed end wrench. Which should of worked as well.
Still can't believe how easy it is to do brakes..
Does anyone know if there was a TSB for the maxima's front seat that rocks? I mentioned it to the service advisor on saturday and he tells me he never heard of that. Only on the Murano's..
Old Nov 17, 2014 | 09:59 PM
13Maximasv's Avatar
I think these cars have some sort of braking system that applies the brakes evenly and that actually causes the rear brakes to wear first.
I only had my car until about 7k miles but I looked at the courtesy check said front brake 9mm, rear 7mm
http://x.nissanhelp.com/forums/Knowl...html?catid=206
http://x.nissanhelp.com/forums/Knowl...html?catid=288
Old Nov 19, 2014 | 10:33 AM
andremike's Avatar
I couldn't find a TSB for the rocking seat? did i miss it?
Old Nov 19, 2014 | 11:22 AM
Maxgig's Avatar
I'm not sure if there is a TSB for the Maxima seat problem but I bought my Maxima used and bought an extended warranty and when my seat started to rock I got it fixed using it. Btw, my car only had 33k miles when the seat gave me trouble.
Old Nov 20, 2014 | 08:36 PM
13Maximasv's Avatar
I'm not sure there is a TSB for your problem
NTB13-063 2009-2013 NISSAN MAXIMA; FRONT PASSENGER SEAT ABOVE NORMAL VIBRATION AT HIGHWAY SPEEDS
The front passenger seatback has a greater than normal vibration at highway speeds
NTB11-036a -REVISED-
2009-2011 NISSAN MAXIMA; REVISED FRONT SEAT BACK SERVICE PROCEDURES
For 2009-2011 Maxima vehicles, new front seat back disassembly and assembly procedures have been developed as the result of some service parts now being available
Old Nov 23, 2014 | 09:52 AM
mls277's Avatar
Congrats. Favorite car I ever owned. Actually may trade for a leftover 2014 this week.
Old Nov 25, 2014 | 08:41 AM
andremike's Avatar
Is the MPG calculation by the speedo different then the one in the center console? If so How do you reset the one by the speedo?
Old Nov 25, 2014 | 10:00 AM
j_dubb's Avatar
Press the display button to cycle through the displays until you reach the one that displays your average MPG and the distance (or is it time?) it's the one with two numeric values, one on top of the other.
When you've cycled to this view, hold the secondary button (the one just down and to the right of the cycle button) down for about 3 seconds. It should reset those numbers to zero, and it'll also reset the average MPG "meter" to zero as well.
Old Nov 25, 2014 | 06:45 PM
andremike's Avatar
Thanks that worked
I noticed today my ipod was crackling and skipping.. I think it may have been the cheap cable. Never heard anything like it before.. I tried and apple cable and so far so good. but haven't tested it much.
Can the songs on the ipod be downloaded to the musicbox?
4doorGTR
Aug 21, 2015 06:19 PM
Mcnabb34
Aug 11, 2015 08:45 PM
Bruceharrison
Aug 9, 2015 07:56 AM
xUNIxPanther
Aug 5, 2015 09:31 AM
