problem with heated/cooled seat knob
Old Nov 24, 2014 | 12:34 PM
dragon27's Avatar
problem with heated/cooled seat ****
i have an 09 maxima and recently, when I turn on either the heated seat or cooled seat ****, it lights up, but shuts off 4 seconds later and stays off. however, the passenger side heated seat still works the whole time.
I checked the fuse anyways and its fine. I checked the wiring thinking maybe there is a loose wiring or soldering job and its fine as well.
can the problem be a result of a faulty thermostat? what else can it be that is causing this? I called the dealership and they said they never heard of this problem on a 7th gen maxima...
Old Nov 24, 2014 | 02:01 PM
Nopike's Avatar
FSM states that if the climate control seat system turns off in 10 seconds or less from the time it was turned on the cause is electrical. Such as a defective TED or blower motor. See if you blower motor is functioning other wise the seat will need to be removed to check or fix anything.
Old Nov 25, 2014 | 08:58 AM
andremike's Avatar
When the **** is on heat, Does the seat still blow air? or does it only blow when its cooling?
Old Nov 25, 2014 | 11:58 AM
dragon27's Avatar
i need to check that out. thanks for replying...
Old Nov 25, 2014 | 04:47 PM
Nopike's Avatar
You can check fan operation without removing the seat. The rest of the system will require removal of the seat. Your fuses and switches for the climate control seat are probably fine.
The fan should be running regardless if it is on heat or cool. The way the system works is the TED's (thermal electric devices) provide heat or cool. The fan circulates the heat or cool through the TED's and by ducts to the seat back and bottom.
If there is no air circulation through the ducts because the fan in not operating properly you will not get any heating or cooling.
Actually, the system shutting off and going into fail safe mode, like yours is doing, is quite common.
There are temperature sensors in each of the TED's. If they failed you would have to replace the entire TED. The system consists of two TED's, one fan, a control unit and the wiring that connects them. These are all mounted in or under the seat. One of those components has probably failed electrically.
You may find this thread interesting.
https://maxima.org/forums/7th-genera...ry-solved.html
Everything you want to about the seats and than some is in the "SEAT" section of the FSM.
http://www.nicoclub.com/archives/nis...e-manuals.html
Old Nov 26, 2014 | 12:16 PM
dragon27's Avatar
Thanks for the reply
Old Jan 25, 2015 | 11:07 PM
Mogenobe's Avatar
My 2010 max was doing the same thing, seat heat/cool shutting off after a few seconds. Had to replace the battery and now heat/cool works just fine.
Old Jan 26, 2015 | 06:57 AM
Nopike's Avatar
If the voltage provided to the climate control seats is not stable and drops below a set value the system will go into fail safe mode and shut down. So that makes sense. Although with a faulty battery I would expect the car to have other issues also.
Old Jan 29, 2015 | 10:19 AM
jasn's Avatar
This may be the same, well-discussed problem with earlier models and I never saw a good fix for it. Does the seat heater (light) come back on if you restart the car? My '11 did that, but only if I start it out on Max setting. One click lower and it doesn't overload. Let it warm up a bit at a lower setting and then you can turn it to Max.
My '12 has no problems.
Mar 12, 2020 12:06 AM
GregL65
Jan 17, 2020 08:01 PM
fakiesi
Sep 19, 2015 12:37 AM
slowlifer
Sep 8, 2015 05:53 AM
GregL65
Sep 5, 2015 09:37 PM
