Power Steering Fluid Change
Old Feb 4, 2015 | 10:14 AM
LSExplorer22's Avatar
The manual does not state exactly at what interval our ps fluid needs replacement. It just says to inspect. Based on my prior vehicles, I feel that 75k would be a fair amount of miles to replace my ps fluid. I am having no issues with my power steering nor does the fluid have a strong smell to it. Does 75k sound like a good interval to replace the fluid?
Old Feb 5, 2015 | 08:40 AM
gizzsdad's Avatar
Probably not necessary, but if it gives you peace of mind - go for it!
Old Feb 5, 2015 | 02:43 PM
Maxgig's Avatar
I agree totally. I change the fluids in my old school car because it gives me peace of mind and I'll change my CVT fluid every 50k miles for the same reason.
Old Feb 6, 2015 | 09:30 PM
CorollaULEV's Avatar
Yup - I changed mine out at around 35K and just a couple weeks ago at 135K miles. I used Valvoline synthetic ATF (Dexron VI) both times.
If you plan to do this yourself, fair warning, it's a real B. You might get something to siphon the fluid out of the reservoir without taking it loose. I loosened the reservoir from the strut tower (wicked frustrating because the bolts are...well you'll find out), tipped the reservoir down and unhooked the hose at the front. Without car running, if you just turn steering wheel back and forth several times lock to lock, it will get majority of fluid out. Also, do yourself a favor and remove the radiator reservoir - only 1 bolt and it gives a lot of extra room to work there.
Late,
Trav
Old Aug 8, 2016 | 10:17 AM
bluefish7's Avatar
ATF vs PSF
Are the branded power steering fluids (RP, etc) basically the same as ATF when its Dex VI? I got nervous when I realized that I had been flushing with Oreilly Dex VI ATF but as far as I've read, it is the same chemical make up. Any thoughts?
Old Aug 8, 2016 | 03:44 PM
14blackbeauty's Avatar
I just replace the fluid in the reservoir and thats good enough for me I use a turkey baster! Yes the turkey tastes different that year hahaha but that is really all I do!
pkfinn
Jan 3, 2016 02:55 PM
Andy29
Aug 31, 2015 01:59 PM
hydriplex
Aug 28, 2015 02:13 PM
Mrbizness1
Aug 18, 2015 08:43 PM
scarletsosa
Aug 17, 2015 09:09 PM
