Morimoto Type-N LED Fog light install
I finally had the chance to install my Type-N fogs from TheRetrofitSource. With them being a direct replacement for our OEM units, I knew the install would be sweet and easy! After taking down the front bumper, it was a matter of removing the two torx screws that hold in each fog light and screwing in the new ones. The H11 connectors are unattached, so you get the chance to plug in the leads and test. That way once you plug the leads in the connector, you get the harness to "click" the correct way.
I really like the way the led looks in the housing, it looks very OEM! I have attached a few pics of the install process, but guys it's a no-brainer install. If you have removed the bumper before, then this install is approximately 30 minutes, tops! I am very meticulous and I was done in that amount of time.
I will updating later with night time pics, but man are they bright in the daytime! If you are looking for a nice upgrade for your fogs, then look no further!
Edit.... Pics!!!!!
Edit.... Pics!!!!!
vingodine
45
05-21-2016 12:46 PM
Viralkill
08-17-2015 10:54 AM
98nismomax
08-13-2015 12:44 PM
