service engine soon??
Old Mar 26, 2015 | 10:10 AM
GNCMaxima's Avatar
Has anyone ever gotten the service engine soon light on by putting the stock filter back on? I had a stillen cai and swapped it many times before but this time i get a light :/
Old Mar 26, 2015 | 11:15 AM
Richard66's Avatar
Check thoroughly that everything is hooked up, could be a loose wire or vacuum hose.
Old Mar 26, 2015 | 12:41 PM
Tommy6905's Avatar
Did you scan it to see what code it is?
Old Mar 27, 2015 | 02:49 AM
GNCMaxima's Avatar
It said MAF sensor. It's weird but I thought codes usually pop up when you go from stock to aftermarket, not aftermarket to stock lol
Old Mar 27, 2015 | 04:00 AM
Tommy6905's Avatar
It'll probably just work itself out, but you can always clear it and see if it comes. As stated above make sure everything was installed properly which I'm sure you did but double check
If you clear the code and it comes back there's some type of issue, try that and we'll go from there
Old Mar 27, 2015 | 05:42 AM
Akiyukio's Avatar
I had that code, though my car is stock. Turns out I needed a ECU reflash.
If you haven't gotten the TSB done, might want to look into it. Else, if you already had the TSB done, I'm not sure.
Old Mar 27, 2015 | 10:11 AM
GNCMaxima's Avatar
Originally Posted by tommy6905
it'll probably just work itself out, but you can always clear it and see if it comes. As stated above make sure everything was installed properly which i'm sure you did but double check
if you clear the code and it comes back there's some type of issue, try that and we'll go from there
+1
Old May 16, 2015 | 10:02 AM
GNCMaxima's Avatar
Im getting the Reflash right meow! Hopefully this fixes the problem...im at 58k miles right meow lol
Any more feedback on other members that had this done too?
shilov
Feb 19, 2024 09:40 PM
Pixel
Sep 15, 2015 05:53 AM
seesole
Sep 14, 2015 12:38 PM
Steven Orozco
Sep 12, 2015 10:41 PM
jfl330
Sep 4, 2015 01:44 PM
