Morimoto XB LED Fogs (Type Nissan)
Old Jun 4, 2015 | 09:33 AM
saltohio's Avatar
I'm just about ready to pull the trigger on these fogs: http://www.theretrofitsource.com/com...l#.VXB7y89VhBd
Questions to anyone who has done this install:
Is it necessary to deinstall the front bumper to remove the old fogs and install these? I'm a bit uncomfortable removing the bumper, I could do it but would prefer not to....
Also, I installed Morimoto XB35 HID's 6K for low beams, I'm wondering what the contrast will be between the 6K HID's and 5K LED's...comments?
Thanks everyone, this board has a wealth of knowledge!
Old Jun 4, 2015 | 09:58 AM
dmcmahan12's Avatar
You can always pull the front wheels and remove the fender liners and gain access that way. 6000K has a hint of blue tint to it and the 5000K will be a bit whiter. Somebody correct me if I am wrong on the color.
Old Jun 4, 2015 | 10:08 AM
Daaavid's Avatar
There is a chance that you will have to drop the bumper, but in the meantime, you can exchange the foglight bulb by removing the plastic covers directly underneath the front bumper. See if you can access the screws that hold the housing in place and if there is enough room to drop the entire housing downwards. It will definitely be easier to drop the bumper.
As for the color temperature difference, they are rated exactly at 5K so yes there will be a color contrast between a bluish white to a very true white.
Old Jun 4, 2015 | 12:05 PM
VVhite-0ut's Avatar
Hey Salt, any reason why you're picking the LED over the HID?
Old Jun 4, 2015 | 01:06 PM
saltohio's Avatar
Feedback from TRS is that the LED fogs will project better, the OEM reflector housings are really not designed for a HID application (according to the response i got from TRS).
Old Jun 4, 2015 | 01:16 PM
mikekay's Avatar
Get yellow LED fogs and direct swap them! I love yellow fogs
Old Jun 4, 2015 | 01:18 PM
RR5's Avatar
RR5
In for pics!
Old Jun 4, 2015 | 01:25 PM
saltohio's Avatar
You - Click here to change
2011 Nissan Maxima: I installed your Morimito XB35 HID'S 6K for low beams and like the output, don't know If I should go with these for fogs or go with the Type NISSAN LED fogs. which would project better?
Carlos @ TRS
The Type N fogs will perform alot better since the width is increase plus there is no need for ballast bulbs or harness.
Old Jun 4, 2015 | 03:58 PM
WesHild's Avatar
Just have to remove the cover under the bumper. Lots of room to remove the whole fog light. Dont know what the Morimoto Led Fogs are like, but HD is much brighter than Led. Hd the fogs all the way!
Old Jun 5, 2015 | 05:44 AM
VVhite-0ut's Avatar
Well, I'm in for pics too then on these LED fogs! Let's see 'em!
Old Jun 5, 2015 | 12:14 PM
CanadianMoFo's Avatar
I installed mine without removing the bumper. Just felt around for the two torx screws, undid them. Pulled the originals out. Wired up the Morimotos, checking polarity before I put the ends together. Popped them up and screwed them in. Wasn't super comfortable reaching up and around but it was quicker than pulling the bumper.
CM
Old Jun 5, 2015 | 12:44 PM
saltohio's Avatar
CM
Good deal Canada, exactly what I wanted to hear!
How do you rate the light quality and spread of the LED fogs? are you happy with the results?
The Frye
Sep 2, 2021 11:03 AM
MaxLife17
Jun 27, 2019 01:37 PM
MaxLife17
Sep 8, 2015 02:36 PM
Pnjboyzz
Sep 4, 2015 09:04 AM
TheMafia
Sep 4, 2015 08:26 AM
