First Winter with Max
Old Oct 16, 2015 | 07:49 PM
MaximaGuy14's Avatar
As the cold weather is approaching in Pittsburgh, this is my first cold season with my Maxima. I have searched, but could not find what I was looking for exactly. My question is how does the car handle in the snow. I sold the Goodyears that the car came with and now have the Michelin Primacy MX4's on the car. One of the several reasons why I bought those tires is because they seem to have a better snow rating than the Goodyear's. My car has the 19 inch rims on them so will that make it harder more of a challenge then say the 18's. Winter tires are not an option for me right now. Aside from the tires, i just want to know in general how does the car handle. My 07 Altima 3.5 with winter tires was actually a disappointment in the snow as well. I suspect the Max won't be much better but who knows. I guess if it gets to nasty I can take my moms Fusion, that car is a tank in the snow. I also drive like I got some sense so hopefully that will be in my favor. Also should I disable the reverse tilt down feature in case the mirrors freeze or do you guys let it go. Looking forward to using my heated steering wheel and seat in the cold temps. Thanks in advance
Old Oct 17, 2015 | 06:30 AM
MaximaDrvr's Avatar
I don't use the reverse tilt mirrors ever.
We don't get a lot of snow in Nc, but we had about 3" last winter and the car did fine.
I was also lowered on coils, and still didn't have problems besides plowing with the front lip.
Just don't be stupid and you will be fine.
18 vs 19 doesn't really make a difference in the snow. Just make sure your tire pressure is set correctly (I recommend 35-36psi). I had those tires in a 225/45/18 on a previous car and they were perfectly fine in the snow. Between my FIL and myself we probably have 400,000 miles combined on those tires.
Old Oct 17, 2015 | 10:53 AM
bheintze's Avatar
I never use the reverse tilt down anymore either, as last winter I experienced a freezing mirror.
As for tires, I ran the stock 19s for a few weeks last winter here in Metro Detroit. Honestly, it was not that great, with reduced stopping/acceleration/control as compared to my prior Camry SE with 17s. I now have Michelin snow tires on 17s, and the car plows through the snow like a tractor.
My suggestion would be to try out the 19s, while saving for some snow tires. Another thing to consider is the price of replacing the factory 19s if you crack one in a pothole. Do that once or twice and your snow tires are paid for.
Old Oct 17, 2015 | 12:26 PM
Get dedicated snow tires. Thank me later.
Old Oct 18, 2015 | 04:53 PM
zoemayne's Avatar
If you have the OEM battery make sure it's in top shape. I don't think the earlier smaller batteries can take 3 winters.
Old Oct 18, 2015 | 08:23 PM
mr Jones's Avatar
The stock tires are utterly worthless if 1 single snowflake is on the ground. And with all our hills and awful potholes, strong winter/all seasons are mandatory.
Old Oct 18, 2015 | 09:24 PM
Maximam's Avatar
Continental DWS 06....Done.
Old Oct 19, 2015 | 03:19 PM
Drag0n97's Avatar
^that what I'm gettin dws 06
Old Oct 21, 2015 | 09:13 AM
LSExplorer22's Avatar
I have the same Michelin tires as you. I commute 85 miles each way in NE Ohio, so I understand the weather you go through. These tires are good and if you drive responsibly, you'll be fine with them.
Old Oct 22, 2015 | 01:38 AM
Thanks. Its good to know that these tires aren't too bad. I wouldn't plan to go out if it's terrible outside unless I absolutely had too.
ThomasofSodor
Mar 22, 2018 08:18 PM
spidgeon
Aug 31, 2015 08:37 AM
tnewbs
Aug 28, 2015 10:15 AM
Flores94
Aug 13, 2015 01:17 PM
alejoa33a34
Aug 5, 2015 09:21 AM
