Help with Niche wheels
Old Dec 25, 2015 | 01:27 AM
A35stormtrooper's Avatar
Im looking to purchase a set of Niche Vicenza wheels. Is it possible to go 20x10.5 30mm in the back and 20x9 35mm up front? I want the flush look, no poking. Im currently at stock height and no rolled fenders. If it will work, what size tire should I be looking at without rubbing?
Old Dec 25, 2015 | 07:52 AM
MaximaDrvr's Avatar
You need et 40-45 in the rear for that width.
Old Dec 26, 2015 | 01:25 PM
I can't find these wheels with anything greater than 30mm for the rear. Can I use a spacer? Sorry, I'm completely new to the whole wheel game.
Old Dec 26, 2015 | 02:51 PM
Maximam's Avatar
Front is good rear needs to be a 40mm
Old Dec 26, 2015 | 03:36 PM
MaximaDrvr's Avatar
No, spacers make the offset lower and push the wheel out further. You need the wheel to be in more.
Just go with the front wheels on all 4 corners. You will be happier that way.
Stagger may look good, but it is more expensive because you can't rotate your tires, and it makes a (our) car handle like crap.
Old Dec 26, 2015 | 06:28 PM
Maximam's Avatar
Totally agree! I run square as well!
Old Dec 28, 2015 | 10:11 PM
So if I run a square at 20x9 35mm will I be flush at stock height or will it poke? I do plan on lowering it on eibachs soon will it be flush on eibachs as well?
Also, what size tires should I be looking at, I live in nyc and the potholes are bad.
Old Dec 29, 2015 | 09:32 AM
MaximaDrvr's Avatar
255/35/20
You will very close to flush all the way around at stock height.
When you lower on eibachs you would need small spacers to stay flush, or just leave them slightly inset.
Old Dec 29, 2015 | 02:48 PM
Maximam's Avatar
You could use a 255 but if you want the closest diameter to a factory setup go with a 245/35.
I run 20x9 35mm square on Eibachs.
Old Dec 29, 2015 | 06:31 PM
MaximaDrvr's Avatar
255 is a better fit on a 9" wheel, and only 1% larger than stock.
Old Dec 29, 2015 | 06:36 PM
Maximam's Avatar
An idea of what 245 looks like on a 9" for reference:
Old Dec 29, 2015 | 06:37 PM
Maximam's Avatar
"Taste Great!" "Less Filling!" ;-)
95maxrider
Nov 24, 2019 07:32 AM
Maximam
Feb 10, 2016 04:48 PM
chanu554
Jan 14, 2016 05:17 PM
Pnjboyzz
Dec 22, 2015 06:45 PM
The Wizard
8th Generation Classifieds (2016-)
Dec 19, 2015 11:24 AM
