Help regarding steering lock failure
Old Jan 17, 2016 | 05:18 AM
Feras's Avatar
Hi,
My steering lock failed on my 10 SV , so I tried the tapping technique and the vehicle started. After that, I've removed the fuse while the car is running. so my question is , would this be a permanent solution or I need to replace the steering lock assembly? by the way there's no KEY indication after removing the fuse.
Note: I'm not from the US.
Old Jan 17, 2016 | 08:01 AM
oldngivout's Avatar
Willing to learn
Removing the fuse under the hood for the steering lock will disable the system. Of course this must be done when ignition is on, steering unlocked, just like you did.
After this the steering lock will no longer function, but it won't hang up and disable the car either.
No need to replace the lock mechanism. You should be ok.
Old Jan 17, 2016 | 08:36 AM
Richard66's Avatar
If you do decide you still want this feature fixed, Nissan extended the warranty to 6 yrs, unlimited miles.
Old Jan 22, 2016 | 12:06 AM
Feras's Avatar
Thank you for your response. The vehicle is running for the past 5 days with no problem.
Old Jan 22, 2016 | 12:08 AM
Feras's Avatar
I think they extended the warranty only for 09 models.
Old Jan 22, 2016 | 07:28 AM
oldngivout's Avatar
Willing to learn
And for MY10 Maxima built before Oct. 2009....
MIDNITE1
Jan 1, 2016 01:02 PM
coskuntarik
Dec 24, 2015 12:00 PM
maxipower
Dec 23, 2015 05:31 AM
JRod28
Dec 20, 2015 05:22 AM
GregL65
Dec 18, 2015 03:26 PM
