How to disable the VDC, TCS, and ABS completely
Old Jan 28, 2016 | 06:52 PM
Maxxx10's Avatar
Exclamation How to disable the VDC, TCS, and ABS completely
Hello everyone..
I will show you some ways to disable this systems completely
Let's begin..
The first way is the Easiest and the Quickest way to disable the whole system BUT....
Warning !!!!!!!!! : Be careful.. If you do that you will haven't a good breaks even in slow speeds, so make sure the road is empty.
1- you should to turn the car ON.
2- hold the break pedal with your feet.
3- hold this buttons at least for 5 second.
4- remove your hand then your feet from the break pedal.
It will disable the VDC, TCS, and ABS.. Which means NO BREAK AND NO SYSTEM CONTROL.
OK, if you need the breaks but you want to disable VDC and TCS only..
I have the solution for you..
It is safe but it will take some time..
1- open the car hood.
2- open the break fluid tank.
3- if you found this filter, try to remove it with a very small and strong stick.
4- then you will see this thing looks like a button. Push it carefully and hold it with a stick or something for 5 to 10 second.
5- then close the break fluid tank.
### If you finished, just turn the car OFF then turn it ON again and it will back normal ###
Remember :
Share it with your friends who have maxima 2009 to 2015
And
Enjoy drifting in streets..
Any problems or difficulties, you can add me on BBM : 5205DDD1
The two buttons
After holding break pedal
Press the buttons
Holding for 5 second
Enjoy..
Break fluid tank
The filter
The white plastic button above the oil which you should press it down for a few seconds
Juan M. Marroquin
Feb 1, 2016 12:20 AM
tobyhatesmemes
Dec 10, 2015 03:52 PM
mrjamaica98mx
Dec 7, 2015 04:29 PM
maximillion98
Dec 5, 2015 12:58 PM
hrobins
Nov 28, 2015 09:49 AM
