MUFFLER DELETE w/ Resonator??
Old Feb 10, 2016 | 10:43 AM
RippinUdders's Avatar
Hi everyone! I'm new here but I've had my 09 Maxima SV since 2011 and its finally time to do some stuff with it.
So! I don't have too much money to spend and I want this car louder so the muffler delete option is very attractive to me.
I'm just wondering if you've deleted your muffler and put a straight pipe on and ALSO if you deleted the resonator that's attached to it.
The muffler and its resonator right behind it
Old Feb 10, 2016 | 10:57 AM
NmexMAX's Avatar
dot dot dot ...
I'd suspect it be wayy too loud for most peoples taste on here. Maybe start with just a resonator delete.
Get rid of that large barrel looking thing after #8.
Old Feb 10, 2016 | 11:00 AM
I'm not thinking about removing number 8, if that's what you're thinking when I say "resonator ". I'm taking about the resonator at the bend of numbers 12/13.
So take off the resonator connected to the muffler and leave the mid resonator there.
Old Feb 10, 2016 | 03:46 PM
MaximaDrvr's Avatar
I would leave those if I were to delete the mufflers.
I put magnaflow mufflers on mine to replace the muffler and mini resonators.
It was still fairly quiet.
I then removed the factory large resonator.
There was too much drone on the highway.
I then added in a small resonator where the factory large one used to be and am happy with it.
I would recommend cutting off the mufflers first and see what you think. Then cut off the mini resonators if you think you want more. It is a lot easier to remove than put them back.
Old Feb 10, 2016 | 03:47 PM
Ok I'll keep that in mind. Thank you for your help!!
Anything else I should know?
Old Feb 10, 2016 | 04:01 PM
MaximaDrvr's Avatar
It would be fairly easy to try yourself first, by buying some clamp on turn down tips.
You could cut off the muffler and clamp on the turn downs and try that for a while. The, if you like it, get some extensions welded on with real tips.
If you want more, take off the turn downs, cut off the mini resonators, then put the turn downs back on. Would be a cheap way to try before you make it more permanent.
It would just look a little funny for a while when you have no exhaust tips at the rear.
Old Feb 10, 2016 | 04:07 PM
Yeah I guess you're right. But I have a family friend who can hopefully do it for cheap. So I'm thinking of that. Cause I really do want more noise. I'm done with my friends Ford Contour sounding nicer than my Maxi xD
Old Mar 4, 2016 | 01:34 PM
jeffrotexas's Avatar
I just installed a custom cat back magnaflow exhaust and it is way to loud. I am thinking about putting the factory resonator that is just after the cat. Any good advise would be appreciated.
Old Mar 4, 2016 | 03:59 PM
Put that resonator back on it you think it's too loud. I still have the main resonator attached (the one after the Y-pipe). The resonators that I got removed are the 2 softball sized ones right BEHIND the mufflers. But yeah. If it's too loud, put the large resonator back on. Its a good volume with minimal drone
RobMax
Feb 14, 2018 06:57 AM
Pnjboyzz
Jan 5, 2016 09:44 AM
rhhilton
Dec 30, 2015 12:30 AM
Quantumxl
Dec 26, 2015 11:26 AM
13r1an
Dec 12, 2015 08:26 PM
