Engine Oil Capacity
Old Apr 5, 2016 | 08:17 AM
iMAK's Avatar
Engine Oil Capacity
Hi,
In the owner manual which came with the car, the drain and refill with oil filter change is 4.2 Liter, while in the same manual which I downloaded from the net it states 4.8 Liter.
Original Manual
Downloaded Manual
Both Manuals are for 2011 Model, so which one to follow? 0.6 Liter I think is a big difference.
Old Apr 5, 2016 | 08:25 AM
glockedc's Avatar
at Advance Auto parts it says they takes 4.9 quarts in their system and I just replaced my oil in my 09 and used the whole big jug of I think 5.1 quarts and put the whole thing in.
Old Apr 5, 2016 | 08:37 AM
iMAK's Avatar
This is really confusing. I followed the original manual and I'm now on 4.2 Liter!
Old Apr 5, 2016 | 08:43 AM
mikekay's Avatar
The paper manuals get swapped around alot even though you are super sure that the paper one is the correct one. I would always say electronic trumps because if there is a mistake that goes noticed at least it can be corrected there.
Old Apr 5, 2016 | 09:15 AM
LtLeary's Avatar
Don't get too hung up on the "capacities" ratings. For example, never run your gas tank dry, even though it says you can add 20 gals....if you do you are in bad shape!
So take these all with a grain of salt and use them as "guides." When you change your oil, NEVER just dump in 4.2 or 4.8 litres. Last I checked, I couldn't buy a .5 liter can of any oil!!! Always add a qt (liter) at a time until you get close (I use 4 qts to get close in my 09) and then, a bit at a time until your dipstick says it is correct. But then, having changed my oil in my 09 64 times so far (every 5000 miles) I have a really good idea on my procedures, time to let drain, angle on the ramps and filter type so I can get close to the mark by "eyeball" now. But even so, I still use the dipstick as the final arbiter (on level ground!)
Old Apr 5, 2016 | 09:37 AM
iMAK's Avatar
You were right, I checked my brother's 2013 Max original paper manual and it was mentioned 4.8 Liter. It's obvious now that the manual was updated.
Old Apr 5, 2016 | 09:40 AM
iMAK's Avatar
Exactly. After I confirmed it's 4.8 Liter I added another 0.6 to 4.2 liter, run the engine for a couple of minutes and checked the dipstick and was spot on the H letter.
Old Apr 5, 2016 | 11:30 AM
2014Maxima's Avatar
It usually takes 4 3/4 - 5 quarts for mine.
Old Apr 6, 2016 | 01:08 AM
iMAK's Avatar
Thank you everyone for your participation.
Old Apr 6, 2016 | 06:27 AM
Maximam's Avatar
I always dump in 5 qts. with filter change.
Old Apr 11, 2016 | 05:22 PM
2young2retire's Avatar
Use the larger filter and dump in the 5qt container of Mobil 1.
reallywildstuff
18
Oct 29, 2019 10:09 PM
mattz300
Detailing
Jun 13, 2016 02:03 PM
JDM_A33
Apr 3, 2016 02:33 PM
Eagle6705
Mar 17, 2016 09:32 PM
DuckSauce
Mar 8, 2016 04:05 PM
