Access to front dash speakers
Old May 6, 2016 | 06:09 AM
erazz's Avatar
Is there any documentation or anything how to get to the speakers in the top dash? I have the most annoying rattle coming from what sounds like that area, maybe a loose wire or something, but cant find anything out there really showing how to do it on the 2010 (im also assuming its not easy!). Although when i do lean closer to try and pin point it, it sounds like it could be in the arm piece leading to the roof (not sure what I would call it). I've had Maxim'a since 2001 and this one by far is the cheapest interior and the most rattle of any of them....enough to have me thinking about ditching the Maxima's! Anyone else have rattles in that area?
Old May 6, 2016 | 09:04 AM
MaximaDrvr's Avatar
If I remember reading correctly, it is fairly simple.
You remove the A-pillar trim and then the speaker cover pops off.
Old May 6, 2016 | 10:39 AM
rayz336's Avatar
OP, I personally don't have any rattles in that area. I hope you're able to get it taken care of quickly
Old May 6, 2016 | 02:35 PM
Nopike's Avatar
I just solved a rattle that was on and off for 2 years. Initially I though the rattle was coming from the windshield or the speakers. Turns out it was coming from overhead, which made it difficult to locate. The problem was the overhead light/sun glass holder. There are wires in the assembly that are loose and they were bouncing around. The noise was more noticeable when the weather was cold. I bet many 7th Gens have this issue.
Old May 7, 2016 | 09:20 AM
erazz's Avatar
Wow, it was in that different of an area huh? I'll check everything, but how in the hell do you get the A pillar cover off? Its in there pretty tight, do I need a specific tool or something?
Old May 8, 2016 | 06:47 PM
Nopike's Avatar
It is easy, no special tools required just give it a good tug. After that you will need long nose pliers. The link below is to the FSM. All kinds of good information.
http://www.nicoclub.com/FSM/Maxima/2010/
TonyMaximaSR
Jun 7, 2023 03:26 AM
Max16SR
Jul 29, 2019 09:27 PM
valerit1
May 19, 2016 04:13 PM
District
Apr 17, 2016 01:16 PM
yeah, thats my max
Mar 4, 2016 08:29 PM
