Anyone had a failed belt tensioner pulley?
This is my 3rd Maxima, (97 SE, 03 SE TE, and now 10 SV). I'm currently sitting at 116k miles and I'm going to have my serpentine belt replaced at 120k.
Has anyone who owns a 7th Gen Maxima had to replace your belt tensioner and if so at what mileage? The reason I ask is because the tensioner failed on my 03 Maxima but it was shortly after my radiator sprung a leak and sprayed coolant all over the front of my engine. I believe the car had 113k miles on it at the time.
I'm hoping to get a good comparison number of miles I can use to determine when or if I should do it when I get the belt changed as part of my preventive maintenance.
In the past I've gotten rid of my cars at 130k and 148k miles respectively but this car still looks and drives good, (plus I've added upgrades that I wouldn't want to remove if I decided to sell). So I'm going to keep it until at least 200k plus miles or for another 5-6 yrs. Thanks all.
Truth be told, there were no parallel cracks in the belt and it could have stayed on, but the trick for me was finding a REPLACEMENT belt that would last more than a few weeks before chirping (especially in cold or wet weather.) Finally went with a DAYCO belt that has been going well for about a year but the Goodyear, AC Delco and Gates always seemed to start chirping after a few weeks. I had a Bando actually shred on me. But after going Dayco, no more issues with shredding, chirping or squealing. I always clean the groves with brake cleaner and wipe down with paper towels to get any grease, oil, dirt etc but for whatever reason, only the Dayco 5070670 has had any longevity (to date, knocking on wood!)
Note: When changing the tensioner you WILL need to either pull the power steering pump or use a good metric offset box wrench. I lost a few hours playing with multiple wobble sockets, extensions, universal joint adapters, 1/4 thru 3/8 until I realized my offset wrenches were made for this situation! Doh!
That was the only time up to then and yes, all were one time change. POST replacement is another story.
Thanks for the suggestion on the Dayco belt. I have replaced with Gates belts a few times only to have it squealing later. I replaced the belt tensioner and put the Dayco belt on and no more squeaks, chirps or squealing. Probably didn't need the tensioner but had already bought it. Definitely a pain to get that bolt directly behind the p/s pulley. Offset box wrench is the only way to go.
I would stick with OEM for the belt, I replaced mine with a Gates belt and it started to squeak after like 3 weeks, So I replaced it with another belt I forgot what brand that was and it started to squeak as well so I put an OEM belt and the squeaking was gone and never returned. Double check the tensioner you may not need one you may just need a belt but try to go with OEM if possible, just speaking from my experience..
I replaced my tensioner and belt. $170 total OEM. It's tedious and therefore takes some time, but not hard. Use the time to dust off any rarely used vulgarities in your lexicon and an offset 13mm box-end wrench and you'll be good to go.
I used OEM belt and tensioner for my 2014:
Drive Belt:
https://www.nissanpartsdeal.com/part...g-belt,,11720N
Auto Tensioner:
https://www.nissanpartsdeal.com/part...ng-belt,,11955
Edit: I should add that I just recently did this job about two months ago. I'm no slouch when it comes to internet research for the best deal and you're not going to find a better deal on the OEM parts listed above. I buy a lot of OEM parts from my local Nissan dealership and they have been cool enough to match my online prices. Perhaps yours will be kind enough to do the same and save you a few shekels on shipping. Plus the dealer sources anything they don't have in stock from the next nearest dealer in the network and can have parts in the next day.
Drive Belt:
Auto Tensioner:
CorollaULEV
Feb 5, 2015 02:39 PM
dissolved
Mar 28, 2005 05:00 AM
