Wheel Sensor seals
Old Oct 1, 2016 | 10:01 AM
bow94z's Avatar
Wheel Sensor seals
I am about to replace my tires and move my wheel sensors from my 18's to 19's. Is there seals that I should replace?
Thanks!
Old Oct 1, 2016 | 05:12 PM
MaximaDrvr's Avatar
The tire shop should have the tpms rebuild kits for less than $10 a piece
Old Oct 4, 2016 | 01:58 PM
maxud's Avatar
Just fyi, I had two sensors with slow leaks. When I tried to take the sensors off to rebuild them, the nut galvanically corroded to the stem, resulting in destroyed sensor each time. I don't know how prolific this situation is, but I had good luck rebuilding Acura/Honda sensor. OE Sensors are made by Schrader and there is a rebuild kit for them available, though I doubt the tire shop will charge only $10 for it.
New sensor is not super expensive and you can reprogram the sensors yourself, search for TPMS programming on this forum.
Old Oct 4, 2016 | 02:59 PM
andremike's Avatar
I had my rims refinj ished on my 2010 altima coupe with 70k miles and the tpms sensors were so corroded i had to replace them all. 2 or 3 fell apart when the shop tried to take them off.
So depending on how old they are you might consider orderung a new set for the new rims. Rockauto has them and you can get a set of 4 for $140.00
Then you just need to program the car with them
RTrud
May 16, 2024 05:00 AM
Ricky Green
Sep 24, 2016 05:00 PM
drainwater
Sep 16, 2016 12:19 PM
oGod
Sep 16, 2016 09:01 AM
Slydog1227
Sep 8, 2016 11:33 AM
