Check Engine Light (P0014/P0024)
Old Jun 16, 2019 | 11:58 PM
Freddy007's Avatar
I've got a check engine light that has been identified by a diagnostic tool as Code P0014/P0024 - B Camshaft Position – Timing Over-Advanced or System Performance (Bank 1 and Bank 2) on my 2013. The check engine light will go away when I drive up to higher altitudes for an extended period of time. I live at an altitude of 65 ft, and when I drive above 4,000 ft. and higher, the check engine light goes off and stays off until I return to my home and the light reappears after a couple of days. This has happened several times now, so its not a one time thing. Any ideas on why that is happening?
Old Jun 17, 2019 | 02:24 PM
VeeQue35DE's Avatar
You can check cam sensors with an oscilloscope. Other than that, have you had the timing chain or tensioner serviced?
Old Jun 17, 2019 | 06:48 PM
Freddy007's Avatar
Thanks for the info, but why would altitude affect the cam sensor or timing chain/tensioner?
Old Jun 18, 2019 | 11:55 AM
VeeQue35DE's Avatar
Altitude wouldn't but the fact that the check engine light goes off while it's under load (climbing upwards) means that while the engine is working, the tension on the chain is corrected because of extra engine load compensating for a failing tensioner. It's just a theory though.
Old Jun 18, 2019 | 01:48 PM
LtLeary's Avatar
I think it is a vacuum leak...probably small. A cracked or bent hose.Maybe the plenum gasket?
Old Jun 18, 2019 | 05:14 PM
Freddy007's Avatar
Thanks VeeQue, for that clarification.
Freddy007
Mar 11, 2021 01:43 PM
Coz
Jan 16, 2015 02:34 PM
ssubhash
Jan 18, 2004 07:02 PM
Ramius83
Jan 15, 2004 09:39 PM
BLKMAX
Jul 9, 2002 05:31 PM
