Key stuck in ignition
Old Jul 25, 2019 | 12:31 PM
macadoo's Avatar
Question Key stuck in ignition
My daughter removed the fob (battery Dead ) and inserted the key into the ignition slot...
Now it won't come out
Replaced battery in fob and car starts
2010 Maxima
tried wiggling the steering wheel and shifter
Jiggled
No Joy
Old Jul 25, 2019 | 08:07 PM
mahanddeem's Avatar
How did she insert the key in the place without the fob?
She wasn't supposed to disconnect key from fob.
Does the key wiggle or any movement?
Old Jul 26, 2019 | 04:37 AM
MadMax07SL's Avatar
Damn, it's possible some debris went in with the key, pocket dust, something on the slot it self, either way it's not letting go either because of that, or perhaps the key is not correctly cut, got it in, but a bump in there isn't letting it out. I'm guessing this is the first time you've ever put it in, as you typically don't need to use it except emergency. Wiggling the wheel is the usual fix, but if you've tried that, could be a real problem...sorry I don't have any ideas
Old Jul 26, 2019 | 03:50 PM
Les7311's Avatar
A quick *****pppsssstttttt***** of WD40 and a firm tug.
Dont soak it.
Old Jul 26, 2019 | 05:06 PM
macadoo's Avatar
We will try that... Gave it lots of firm tugs but will move up and down but not out
Old Jul 26, 2019 | 05:07 PM
macadoo's Avatar
She used the key to open the door and just stuck the key into the fob holder... first time she had to use key... Might just leave it there and get new key for fob
Old Jul 28, 2019 | 08:32 AM
zappasian's Avatar
Doh ! You must not put the key in the dash slot at the left of the seering wheel. It is for the keyfob to be able to start your car if the keyfob battery is dead.
Try to insert a thin metal tool on the left, right side or both side of the slot and pull the key out
zoemayne
May 15, 2016 07:45 AM
brichi
Apr 12, 2015 02:36 PM
STiiLO
19
Dec 18, 2013 11:05 AM
Profireman
Nov 22, 2013 11:35 AM
2young2retire
Apr 15, 2011 12:40 PM
