ABS/VDC lights on; will not shift out of Park HELP!!!
Old 11-15-2019, 01:02 PM
Adrian Gaddis's Avatar
Hey there I have a 2012 Nissan Maxima and the ABS/VDC lights came on after adding a plug and play remote starter to the car. Also the car will not shift out of park unless bypassed brake lights do not come on at all. Already replace the brake light switch. Where do I go from here.
Car starts right up every time no problems,
No other Dash lights are on.
Adrian Gaddis is offline
Old 11-15-2019, 04:02 PM
Richard66's Avatar
Looks like your plug/play needs to be unplugged and everything taken back to stock to see if everything is as was. If so then a call to the manufacturer is suggested. BTW what is the remote start you installed and did you check all the fuses?
Richard66 is offline
Old 11-15-2019, 07:23 PM
User1's Avatar
You screwed up your install. Start over.
User1 is offline
GarageToys
07-11-2023 12:21 PM
Badonkadonk
04-14-2018 08:06 AM
maxipower
09-04-2009 03:36 PM
romefolk
07-30-2007 07:14 PM
3.5 Lover
26
06-17-2006 07:18 PM
Quick Reply: ABS/VDC lights on; will not shift out of Park HELP!!!
