Grinding metal on metal sound when accelerating only
Old Dec 15, 2019 | 10:39 AM
mansnothot's Avatar
Hello guys as you can see in the linked below video i have this grinding metal on metal sound when accelerating specially above 2k rpm and only if the car is moving ( no matter at what speed ) it will make the same noise above 2 k rpm below that no noise at all
did any one had this issue before and figured it out
Old Dec 15, 2019 | 12:14 PM
Bificus99's Avatar
Brake or wheel bearing is where I would start.
Old Dec 15, 2019 | 12:27 PM
mansnothot's Avatar
don't think so as the sound is coming from the hood and only when the engine rev is above 2 k and the car is moving ,, plus ive changed the brakes recently
Old Dec 15, 2019 | 01:38 PM
NCSUpilot's Avatar
From what I can hear on the video, it sounds similar to what I had. It turned out to be the collars on either side of the catalytic converter (I think). They had rusted/broken loose, so when you're accelerating, the engine shifts back and causes those rings to move back and jingle.
I know it sounds crazy, but crawl under there and check it out. I ended up carefully cutting them off with a grinding wheel and haven't had an issue since then.
Old Dec 16, 2019 | 08:56 AM
KArthur's Avatar
https://youtu.be/hx-RPiIhcUI
Hard to tell from the video b/c of the wind noise. If you power-brake, do you hear the same noise? Thinking it might be a motor mount and something is rubbing during acceleration.
Old Dec 17, 2019 | 11:33 AM
NCSUpilot's Avatar
https://photos.app.goo.gl/bQH3CL1jMRZLZdmf6
Old Oct 8, 2023 | 06:04 AM
Maxi_me_down's Avatar
Did you find out what it was?
brandnew
24
Mar 6, 2014 07:47 PM
Jamalz
Oct 22, 2012 09:57 AM
pktaske
Mar 14, 2011 11:43 AM
j-dawg
Aug 4, 2010 09:07 PM
Snypa
May 6, 2010 10:20 AM
