Strange Vibration
Strange Vibration
Maybe my wheels are out of balance but when maintaining a speed between 70-80 the car vibrates. Upon letting of the accelerator the car rides smooth. Not sure if I have wheel out of balance or motor mount or something else. Driving me nutz.
any advice?
any advice?
https://www.tirereview.com/when-is-it-overkill/
A road force tire balancer uses a load-roller to simulate the force of the road and gather the combined uniformity of a wheel and tire package. Road force balancers measure the force variation and runout of the whole wheel and tire assembly.
I had the same issue. I had a bent rim and my tires were not balanced properly. A new rim and balance job later my car still has a very slight shimmy but nothing like what was going on at first. Also it seems like my car only does this in the morning. Its almost like the tires have to warm up because after my initial morning drive I don't notice it.
2009 Nissan Maxima SV sport package
Balance and rotate your tires, then see how it goes from there. Also inspect your tires for cupping / feathering (cupping suspension issue / feathering alignment issue). Have you ever felt a loss of power going up a hill? If so, then your coils may be going out, coil issues usually are more present when the vehicle is under load. For older vehicle with ignition wires, problems happen when it's raining.
Check your strut-mounts. Open the hood, and while pushing up/down on the car, observe the strut-mounts to see if there is any play between the strut and the strut mount. The strut's bolt/nut should not move.
If they are good, then start checking each piece of the rest of the suspension for play.
StenholmEngineering
Feb 17, 2010 01:59 PM
2k2PhatMax
Feb 2, 2004 07:35 AM
