Replaced battery. Lost seat and steering wheel settings. Need help with settings
Old Nov 18, 2020 | 03:23 PM
ChelsK's Avatar
I got a new battery and before I did that when I shut off my car all the door unlocked and the seat and steering wheel would move. After I got the new battery I shut it off and none of the doors unlock and the seat nor the steering wheel move. I’ve tried several attempts to change the settings to fix it and I cannot figure it out. Help! I have a 2009 Nissan Maxima SV
Old Nov 18, 2020 | 07:48 PM
Richard66's Avatar
From the owners manual.
AUTOMATIC DOOR LOCKS ● All doors lock automatically when the vehicle speed reaches 15 MPH (24 km/h). ● All doors unlock automatically when the ignition is placed in the OFF position. The automatic unlock function can be deactivated or activated. To deactivate or activate the automatic door unlock system, perform the following procedure:
1. Close all doors.
2. Place the ignition switch in the ON position.
3. Within 20 seconds of performing Step 2, push and hold the power door lock switch to the position (UNLOCK) for more than 5 seconds.
4. When activated, the hazard indicator will flash twice. When deactivated, the hazard indicator will flash once.
5. The ignition switch must be placed in the OFF and ON position again between each setting change.
When the automatic door unlock system is deactivated, the doors do not unlock when the ignition switch is placed in the OFF position. To unlock the door manually, use the inside lock **** or the power door lock switch (driver’s or front passenger’s side)
Restarting the entry/exit function If the battery cable is disconnected or if the fuse opens, the entry/exit function will be disabled. Drive the vehicle over 25 MPH (40 km/h) to restart the entry/exit function. You can also restart the entry/exit function using the following procedure.
1. Connect the battery cable or replace the fuse.
2. Open and close the driver’s door more than 2 times with the ignition switch in the LOCK position.
The entry/exit function should now work properly
Sassy
Nov 25, 2016 07:13 PM
scutmud
Jun 30, 2016 05:16 AM
akurtzer57
May 10, 2008 05:30 PM
kdejour
Aug 11, 2006 08:09 PM
nick
May 21, 2002 01:18 PM
