No throttle/acceleration response problem.
Old Sep 22, 2020 | 06:54 PM
gm2685's Avatar
Please help. I have a 2011 Maxima sv, and I'm having an intermittent problem with my acceleration where i will push the gas pedal down all the way, and get extremely low throttle/acceleration response until i release the gas pedal and push it down again. I already had the throttle and tps replaced 2 days ago, so we can rule that out. I was able to catch this in action with a scan tool if that helps. No codes. Any type of opinions/suggestions would be greatly appreciated.
Old Sep 22, 2020 | 10:14 PM
User1's Avatar
And this is precisely WHY I think this is where you're problem lies.
No codes is untrue. You have a P2135. TPS is built into the throttle body, so I don't know what you mean by "throttle". There are only two things it could be, the throttle body or the accelerator pedal. I think you need to check your TB plug/harness. I'll bet you your issue will be sensitive to how the plug connects to the TB, if not the TB itself. I had a pigtail that came with some other parts for an engine swap (2nd gen VQ into my 5th gen car), my TB just didn't like it. I ditched the pigtail, hard-wired (soldered) my TB/harness and haven't had a problem since. My P2135 would be totally random. I'd get a dash light, lose all throttle control, coast to park, pull codes, clear codes, and be on my way again. It was so annoying.
Old Sep 23, 2020 | 03:57 PM
gm2685's Avatar
Thank you for the response. Yes, my mechanic replaced the throttle body 2 days ago because of this issue, but it persists so I took it back to him.I was thinking it could be the accelerator pedal sensor, but I didn't think to ask him to check the wire harness. I should mention that i had the alternator replaced shortly before I noticed this problem.
Old Sep 23, 2020 | 04:08 PM
User1's Avatar
Pedal is going to be fine. I would suggest a better code reader. I use "Torque" for Android and the BAFX dongle
Amazon Amazon
So you are able to drive the car? Is your issue transient?
Old Oct 20, 2020 | 04:20 PM
gm2685's Avatar
OK so my mechanic (who keeps throwing parts at the car), replaced the throttlebody, accelerator pedal sensor, and MAF sensor, as well as checking all the connections , and the problem persists . BUT i may have had had a breakthrough today because i noticed that my car (which is a push button start) was able to start without me pressing down on the brakes (which shouldn't be possible). I didn't notice the brake lights staying on, but is it possible that the brake switch is the culprit? Any insight would help, especially if i can replace the switch myself without spending anymore money!
Old Oct 21, 2020 | 08:08 AM
User1's Avatar
You don't have these problems without codes. You'll get a much better response when you post them, as suggested above. A lot of us are pretty familiar with the FSM for these cars, and one code could have several work flows for several different components. Your mechanic has the time to **** around and throw parts at it because you are paying him by the hour, the forum members are all here for free. Throw us a bone.
Old Oct 21, 2020 | 03:29 PM
gm2685's Avatar
Sorry man, but there are NO CODES, why would I lie about that?. Of course, if there were I would tell you, but that's why this is so perplexing.
Old Oct 23, 2020 | 07:30 PM
VeeQue35DE's Avatar
Has the mechanic done any of the relearn procedures for the parts that were removed and replaced?
Old Oct 28, 2020 | 04:23 PM
gm2685's Avatar
So I replaced the brake switch, and haven't had the problem in 3 days. Hopeful that this was the fix! If so, I wish I had figured that out before paying for a new throttle and pedal sensor.
Old Nov 19, 2020 | 01:34 PM
jws9268's Avatar
Having the same issues on my '14 with 103k , its now happened for the 2nd time.
TonyJr
Apr 29, 2012 10:36 AM
SR20DEN
Aug 20, 2010 10:31 PM
TurDz
Dec 30, 2005 09:03 PM
G4nismo
May 25, 2005 12:47 PM
trubd
Feb 18, 2004 07:56 PM
