Settings on SAFCII on VG30E Lost my book!
Old Mar 6, 2008 | 07:16 PM
akurtzer57's Avatar
Either I lost my book or my GF threw it away but I need to set the Hi throttle and Lo throttle,Th- point,Dec air and sensor type. I have the whole thing hooked up by using the pinout readings and did the initial settings and such just want to get these all done correctly. I have 370cc injectors and the stock MAF just running 4psi for now. Slowly going to work my way up to 10-14 or should I just set it all for the higher boost? Any help from the Vg guys.
Old Mar 7, 2008 | 02:29 PM
NmexMAX's Avatar
dot dot dot ...
http://www.google.com/search?hl=en&c...al&btnG=Search
Old Mar 7, 2008 | 03:22 PM
akurtzer57's Avatar
thanks for that but still need to find sensor type and such.
Old Mar 7, 2008 | 03:25 PM
NmexMAX's Avatar
dot dot dot ...
I used to have 'em on PDF. Damnit.
HW is your sensor type.
Old Mar 7, 2008 | 04:01 PM
akurtzer57's Avatar
I have it set for 6 cylinder, arrow up, hot wire what should I put for in and out. low throttle 25% high throttle 48% 01,01 on the MAF. that ok to go with or should I make some adjustments.
Old Mar 7, 2008 | 04:09 PM
NmexMAX's Avatar
dot dot dot ...
I'd say. As long as the MAF is the same number, assuming you have the stock MAF.
Old Mar 7, 2008 | 04:13 PM
akurtzer57's Avatar
yes have the stock MAF. For the in and out on the hot wire I've seen that most have 4 in and 4 out but that is not for the vg is it the same?
Old Mar 9, 2008 | 12:50 PM
NmexMAX's Avatar
dot dot dot ...
1/1, 2/2, 3/3 etc. As long as they're the same you're fine.
Old May 10, 2008 | 05:01 PM
akurtzer57's Avatar
wrong thread to post in looks like you need to do some research and learn alot.... use the search on supercharger setups.
Old May 10, 2008 | 05:30 PM
d1max2nv's Avatar
you could find the PDF here at this site. good luck
http://www.jrponline.com/downloads/docs.asp
aw11power
Oct 10, 2021 04:57 AM
gigabyte
Jan 6, 2017 06:05 PM
knight_yyz
Nov 1, 2015 01:34 PM
Pnjboyzz
Oct 7, 2015 10:47 PM
