Power outlet not working 09 7th gen maxima
Old Dec 7, 2020 | 03:29 PM
English's Avatar
I had coins drop into my power outlet in front not the one in my hand rest, I took the coins out using a Phillips screwdriver and subsequently seen a brief spark.so i
decided to change the fuse under my steering wheeling thinking that it was burnt however, it didn’t look burnt but i
Changed it regardless it’s a 15a fuse so I changed it with a spare fuse located in the same spot,the outlet still isn’t working any ideas? The outlet in my armrest works fine
Old Dec 7, 2020 | 04:45 PM
User1's Avatar
Wrong fuse?
Old Dec 7, 2020 | 05:05 PM
LtLeary's Avatar
Originally Posted by User1
Wrong fuse?
Best answer!
Old Dec 7, 2020 | 06:43 PM
English's Avatar
I changed the wrong fuse? I followed the direction located on the back of the fuse cover
Old Dec 7, 2020 | 07:14 PM
Captive8's Avatar
Keep looking...did you have the diagram on the lid oriented correctly?
Old Dec 7, 2020 | 09:18 PM
English's Avatar
it was pretty straight forward I thought, but I’ll check again....
Old Dec 8, 2020 | 04:42 AM
LtLeary's Avatar
sparking without blowing a fuse is unusual but not unheard of. If you are sure that the fuse is good it is possible that some "stuff" fell in your outlet while removing the coins. Or, like in my case, the outlet is bad.(it doesnt do well with water in it.)
Old Dec 8, 2020 | 01:17 PM
Les7311's Avatar
Only thing I could think of is the fuse......
hhhhhmmmm
Old Dec 8, 2020 | 07:59 PM
LtLeary's Avatar
You might search this forum. I think someone mentioned a way to remove the adapter without taking the console apart but I slept since then.
sam930
Nov 14, 2021 08:24 AM
TomRS
May 19, 2016 04:21 PM
gofastgt
May 13, 2012 03:17 PM
kicks26
Aug 6, 2004 05:28 AM
Supreme Allah
Mar 10, 2004 09:21 PM
