Serious rattle and miss on startup
Old Dec 26, 2020 | 10:23 AM
Bificus99's Avatar
Hi Hive mind of Maximas,
Twice this week I have started my max and it sounds like I have pots and pans under the hood and a miss. Its repeatable after 2+ days of sitting. My plan is, once its not 20 in the morning, is to change oil and filter, debating if I should get a quart of marvel in it too. Or get a full oil flush at Valvoline. I also have ticking during low speed acceleration.
Or should I punt?
Old Dec 26, 2020 | 12:49 PM
mahanddeem's Avatar
Or should I punt?
What's your engine oil and filter? And how many miles on your Maxima?
Old Dec 26, 2020 | 03:25 PM
Bificus99's Avatar
Castrol edge 5w-40 Mobil filter and 138K miles on the odometer. Been running synthetic 5w-30 Mobil1 for 100k miles.
Old Dec 31, 2020 | 01:42 PM
Bificus99's Avatar
Got 1000 miles before the next scheduled oil change so I put a quart of marvel mystery oil in it as I putt around town. The missing was worrying, The clatter is a known but expensive repair in the timing chain tensioner.
Old Dec 31, 2020 | 01:45 PM
Bificus99's Avatar
I have 1000 miles before my next scheduled oil change so I put a quart of marvel mystery oil in the max. Ill run it around town then change it out. The miss was worrisome, the clatter is more than likely the timing chain tensioner.
Old Dec 31, 2020 | 02:19 PM
mahanddeem's Avatar
Can you post a youtube video to that sound?
Old Dec 31, 2020 | 02:24 PM
Bificus99's Avatar
Its hard to know when it is going to occur since I started treating it, I will try to turn my camera on when I crank it up.
Old Dec 31, 2020 | 06:03 PM
LtLeary's Avatar
If it doesnt occur when starting daily, but gets worse after 2 or more days, I would look at replacing the filter
. The anti-flow back valve in the filter may be weak causing dry(er) start ups.
Old Dec 31, 2020 | 10:01 PM
Bificus99's Avatar
OEM Nissan LtLeary?
Old Jan 1, 2021 | 09:12 AM
LtLeary's Avatar
I use the mobil 1 filter but sure oem or wix are fine too. Any filter could experience this issue but the better the quality filter, the less chance of it happening.
Old Jan 10, 2021 | 10:41 AM
Bificus99's Avatar
Marvel mystery oil is quieting the ticking I also posted about. Cold starts are quieter. So far...
Old Feb 20, 2021 | 11:46 AM
Bificus99's Avatar
Oil change consisting of fresh Castrol Edge 5w-40 with 4oz of MMO have been added this week. Lots better.
Old Feb 21, 2021 | 12:55 PM
mahanddeem's Avatar
I use M1 0w40 and engine is much quieter than any 5w30 I ever used. Even in 20s weather. I trust Nissan oil filters (I use the long version) more than aftermarket ones (including M1 or Fram Ultra).
Old Feb 21, 2021 | 03:34 PM
Bificus99's Avatar
May have to look into those long filters and M1 0w-40.
Old Feb 21, 2021 | 05:19 PM
mahanddeem's Avatar
I mean this filter 15208-9E01A
mclasser
Jan 12, 2016 01:43 PM
Skicrazer
19
Nov 25, 2014 12:39 PM
multiplexor
Aug 29, 2001 11:30 AM
gpburdell
Aug 20, 2001 09:25 AM
