09 oil leak
Old Mar 9, 2021 | 07:05 AM
several's Avatar
09 oil leak
Hello Max family,
Forgive me if this has been brought up somewhere but I cannot find it. I have a 09 Maxima SV sport package. I noticed this past Saturday morning that some oil is leaking from my car. it's not alot. I will say that morning that I noticed it there was more on my garage floor. Again, not alot but more than on the attached photo. It's leaking from somewhere on the passenger side of the engine. I have attached a photo. Does anyone know what this might be? I don't have access to lifts and whatnot and was too lazy to get my jack out and do that to see where it may be coming from. Lol! Any info would be greatly appreciated.
About this much every day since I noticed it.
Old Mar 9, 2021 | 03:47 PM
TDGrant's Avatar
"I don't have access to lifts and whatnot and was too lazy to get my jack out and do that to see where it may be coming from. Lol!"
Go get your jack and look.
Old Mar 9, 2021 | 05:41 PM
AWOLF05's Avatar
Originally Posted by several
Hello Max family,
we are all dumber for reading this post, I award you no points and may god have mercy on your soul
Old Mar 9, 2021 | 06:54 PM
Randy Watson's Avatar
Looks like you’ve got a leaky johnson rod, easy fix. Go to your local parts store and ask for one.
Old Mar 10, 2021 | 07:27 AM
several's Avatar
Thanks guys. You're so helpful.
Old Mar 10, 2021 | 11:09 AM
LtLeary's Avatar
Thanks for being a good sport and putting up with our feeble attempts at humor.
The Black piece you have in the middle of your pan is part of plastic "rivet" or connector. The male piece has a head and tail and would fit into that female piece to secure a plastic piece to the frame. It wouldn't have any impact on oil leakage.
The oil itself looks clean leading me to believe it is from the oil filter or the drain plug (perhaps whomever change the oil last forgot to install a new crush washer??? Unfortunately, you will have to crawl under the car to look or take it somewhere you trust.
If that all looks fine, the next step would be around the valve covers but I would expect the oil to be more "dirty"
Let us know what you find.
Old Mar 10, 2021 | 11:34 AM
several's Avatar
Thanks Lt.
That sounds logical. And yeah I just put that piece in the pan because it was a tad breezy and didn't want the pan to move. My car is at my mechanics now. I'll update when I hear from him.
Old Mar 10, 2021 | 04:24 PM
User1's Avatar
Classic Sandler.
Old Mar 10, 2021 | 04:59 PM
several's Avatar
Happy to report my mechanic said it was the plug. he noticed the washer was missing from it. Whew! You were spot on Lt. BUT I will be stopping by the spot where I got my oil changed bout a month ago and asking why they didn't notice that and or how they forgot to put the washer back on. Didn't have this issue before I took it there.
Old Mar 10, 2021 | 05:21 PM
Reasons like this are why I change my own oil on all of my cars and do as much as the maintenance/repairs as possible. Way back in my 20's, I used to take my car to Walmart for oil changes on my b1tchin' 1992 camaro. Developed an oil leak right afterwards. Turns out, the turkey who worked on my car screwed up the oil pan by crossthreading the oil pan bolt into it. Dealer had to replace the oil pan to the tune of $350ish. When you're making minimum wage at $4.25/hour, that repair really hurt my wallet. From that point forward, I swore to myself I would work on my own cars.
Old Mar 10, 2021 | 06:05 PM
several's Avatar
I hear you loud and clear. I went to this place because it was in my neighbor and they used Mobil 1 oils. I will not be going back. I have a good buddy that has a shop, they guy who figure this out today. I’m gonna just start buying my own oil and taking it to him. I’m just not mechanically inclined. At all.
Old Mar 11, 2021 | 05:22 AM
LtLeary's Avatar
I hear you but like the Wizard, I've had stripped plugs and changes where they don't replace the drain plug correctly. Our Maximas make use of a copper crush washer to get a good seal. You may want to check with your buddy and make sure you bring him some crush washers along with your oil and filter.
Old Mar 11, 2021 | 06:01 AM
maxipower's Avatar
i ve had the same problem of changing oils very often which wears out the crush washer...so i have different sheets of teflons with various thicknes and used 1/16 th inch thickness and made my own washer,,it lasts forever and makes a terrific seal ,,never drop of oil,,
Old Mar 11, 2021 | 06:19 AM
LtLeary's Avatar
Sounds great, got a source of supply for those teflon sheets you use? Not something I see regularly at the local home supply store!
Old Mar 11, 2021 | 07:34 AM
Richard66's Avatar
You can Get it here for .26 each. OEM Nissan part # 11026-JA00A. Get five bucks worth and you are set for the lifetime of your car.
Old Mar 11, 2021 | 08:49 AM
several's Avatar
Thanks again guys. And thanks Richard66. That does sound like a great idea.
Ramay64
41
Feb 12, 2022 07:44 PM
cnadler3
Oct 22, 2020 03:35 PM
JoJo52
Feb 10, 2020 11:15 PM
CamryKilla
Aug 31, 2005 06:34 AM
Sassy Girl
Sep 28, 2004 11:09 AM
