I have a leak on my 09 maxima
Old Aug 7, 2021 | 06:11 PM
JesusC3J's Avatar
I get a 09 maxima, (mechanic special) says it have a new water pump, but the car was incomplete, missing the alternator, thermostat and ac compressor, I install de thermostat and all the hoses and still leaking, it looks like the leak start back to the thermostat, any ideas? Y doble check the thermostat, sorry if my English is not good thank you very much
Old Aug 8, 2021 | 03:03 PM
LtLeary's Avatar
Well, if you are absolutely sire you imstalled the thermostat housing and gasket correctly (I say this as sometes, people dont remove all the old gasket, dirt and oil from both surface) torqued the bolts correctly, then I would be very suspect of the hose. If the hose and clamps are good, you may have a cracked housing
. Please let us know what you find.
Old Aug 8, 2021 | 04:45 PM
JesusC3J's Avatar
I found it
All was good but in February was a very bad weather, it was freezing and I found a water plug out I’m not sure if that’s the name but now I mes to figure out how to change that plug, any ideas?
Old Aug 9, 2021 | 12:11 PM
LtLeary's Avatar
Doing it while the engine is installed will be fun...you need to remove a lot of "stuff" to get good access to the freeze plugs. But once you do, this you tube is pretty good
Old Aug 10, 2021 | 06:13 PM
JesusC3J's Avatar
Need to remove the head
How to Replace Freeze Plugs | Freeze Plug Installation Tool - YouTube
thanks for the video, now I have a better Idea to change the plug, but I need to take de head off to change it, that’s bad haha
Sky's Maxima
Aug 7, 2012 06:57 AM
LudeAEM
Dec 5, 2003 02:00 PM
michaelnyden
Aug 28, 2003 07:02 PM
Ant96GLE
Jun 3, 2003 10:38 PM
blakkrob
Jan 29, 2003 12:16 PM
