Front speed sensor wrong part or bigger issue?
Old Oct 22, 2022 | 10:21 AM
Seanmc980's Avatar
Hello, I've been having an ABS/TC light for the last few months..I finally got it diagnosed to be the front driver side wheel sensor..
I ordered a cheap eBay replacement and tried to replace it. The sensor that came out was about 1/2-3/4" shorter than the replacement part. I assumed that the bad sensor had broken inside the hub, but the new sensor is bottoming out at the length of the old sensor.. when I inspected the port with a flashlight, I can see smooth metal at the end of the whole. I don't know if something shifted inside the hub and broke the sensor, or I did in fact receive the wrong part.
When I search online for the part and look at pictures, they all seem to look about the same length as the one I received, but who knows if these are the actual part pictures or generic.. I could remove the passenger one and compare, but I figured I'd check here first.
Old Oct 22, 2022 | 02:33 PM
LtLeary's Avatar
Cant really tell but it does look like the old one is broken. If so, i would replace the hub as a broken piece insde could have ruined it.
Old Oct 23, 2022 | 07:38 AM
RA030726's Avatar
I'm nutty for Nissans
Install it.
That's not how it works. The bearing is sealed.
Old Oct 31, 2022 | 11:32 AM
LtLeary's Avatar
Originally Posted by JSutter
Install it.
Nobody mentioned bearings...we are talking about the hub assy where the sensor is located to determine the wheel "speed" as the magnetic encoder turns. If anything breaks off or gets that mutilated, you aren't going to get good readings.
knock
Feb 6, 2015 11:05 AM
sabryant
Sep 22, 2014 07:47 PM
cwm9
Sep 19, 2008 09:53 PM
Stagnet04
Jul 12, 2008 12:35 AM
