2010 Maxima - Evap Leak
Old Dec 9, 2022 | 05:25 PM
King2023's Avatar
2010 Maxima - 105000 miles
Check engine light is on
Computer scan states small evap leak
Advised I need a smoke test to see where the leak is, in order for the part / issue to be fixed
Car needs to drive 100 miles, and light should come off
Inspection is due to 2 months
Any help or feedback regarding this issue, or how it can be fixed would be appreciated
Can this be resolved by myself, or a mechanic needs to be the person to fix this issue.
Many thanks
Old Dec 10, 2022 | 08:13 AM
Richard66's Avatar
Could be as simple as the gas cap not making a good seal. Use some emery paper on the filler neck where it makes contact with the cap gasket. Clean the gas cap gasket and apply a thin coat of Vaseline on the filler neck. Clear the code with the battery disconnected for 15 minutes. Reconnect battery and take it for a ride, see what happens. If you decide to change out the gas cap, make sure its OEM. If this doesn't work a smoke test would be the next course of action to see where the leak is coming from.
Old Dec 15, 2022 | 04:58 PM
King2023's Avatar
Thank you, will try, much appreciated
Mmonte
Feb 14, 2020 09:01 PM
egali045
May 24, 2014 01:42 PM
rhonster
Jul 26, 2013 09:44 AM
joemax1
Nov 7, 2006 12:35 PM
