OBDII port not working, brake and gas light on. Need help.
Old Jun 11, 2023 | 02:23 AM
jamarsmalls25@icloud.com's Avatar
I have been trying everything in my power to figure out why my OBD port is not working. Has the bright light on the gas and the speedometer not working. I try my best to look for any grounds in the dashboard wire hornist I don’t have a wire hornist I don’t have any fuses blowing on the hood name on the steering wheel? I don’t know what else to do so anybody help me or leave me in the right direction thanks!!
Old Jun 11, 2023 | 07:32 AM
Anyone?
Old Jun 11, 2023 | 11:32 AM
You post this at 5:23am on a Sunday morning and you expect help right away? oof
Your description is poor. What is the main issue? Brake light is on? How does the car drive and behave?
Old Jun 11, 2023 | 12:30 PM
Yes, it drives ok i guess and my obd port does work I connected my code reader and it doesn’t have power.
Old Jun 11, 2023 | 12:36 PM
Turbobink's Avatar
Old Jun 11, 2023 | 12:44 PM
Why that picture
Old Jun 11, 2023 | 02:56 PM
Again, what is your main problem?
Is the car on (but not running) when you say the OBDII port has no power?
Old Jun 11, 2023 | 03:10 PM
Yes, it’s on the on position
Old Jun 11, 2023 | 06:17 PM
I mean problem is that I can’t get my code reader to connect to the car
Old Jun 11, 2023 | 06:18 PM
yes
Old Jun 12, 2023 | 08:46 PM
yes car on not running and yes OBDll has no power when I connect my code reader. Trying to figure out how to get it back working.
Old Jun 13, 2023 | 12:07 AM
Check out this thread. There are two good suggestions within that worked for other Maxima owners. Let us know if you fixed the problem.
https://maxima.org/forums/7th-genera...obd2-port.html
Old Jun 13, 2023 | 09:16 PM
neither of those suggestions worked 😞
Old Jun 13, 2023 | 10:23 PM
Have you tried using the Search function? I recall a few threads about this issue.
Old Jun 13, 2023 | 10:44 PM
Yea
Old Jun 14, 2023 | 07:20 AM
Richard66's Avatar
Did you try connecting your code reader to a different vehicle to see if it works?
Old Jun 14, 2023 | 08:16 AM
Yes I had and it connected
Old Jun 14, 2023 | 05:05 PM
LtLeary's Avatar
So now is the time to brimg out a voltmeter or test light. Test pin 16 to a good ground. If power there, then check between pins 16 and pin 4. Most likely this will show 0 volts. If no power to pin 16, you have a wiring or connector issue. You are just going to have to use your tools and Mark 1 calibrated eyeball to track it down
Old Jun 15, 2023 | 02:57 AM
q_nerk's Avatar
Are you turn on ignition before you connect obd reader (foot brake relased)?
Old Jun 15, 2023 | 07:56 AM
yes
Old Jun 15, 2023 | 11:59 AM
Costee's Avatar
Any background info? Since when did the scan tool fail to communicate with the car? Any repairs before?
Old Jun 15, 2023 | 12:01 PM
Costee's Avatar
Can't agree with you more.
Old Jun 18, 2023 | 08:02 PM
I’ll say like a month ago I had it hooked up and it cleared a i’ll see you like a month ago I had it hooked up and it cleared code and then next to you know stop working
Old Jun 19, 2023 | 12:41 AM
You know where or wat section of the car to start looking or you know where u can a diagram?
Old Jun 23, 2023 | 05:17 PM
yes I have power from the 16 pin sir
Old Jun 24, 2023 | 03:18 AM
Turbobink's Avatar
Since you’ve tried your scan-tool on a different OBDII vehicle, how about trying a different scan-tool on this vehicle?
Old Jun 26, 2023 | 12:23 PM
Costee's Avatar
Check that the connector pins on your tool are not bent.
Old Jun 26, 2023 | 12:24 PM
Costee's Avatar
Not a bad idea.
Philly1827
Aug 26, 2014 05:07 AM
1gt2nv
Feb 4, 2014 04:43 PM
zero2sixtyZ
Dec 23, 2009 06:42 PM
chris.tremblay
Mar 21, 2004 02:40 PM
vinnieloo
Nov 14, 2002 08:04 PM
