what is this item, washer?
Old Jan 19, 2024 | 08:38 PM
WDM's Avatar
WDM
A repair shop replaced my power steering pressure hose and also replaced 6 spark plugs. During this repair, air intake manifold, air intake box and throttle body were removed.
After two days, I found a washer sitting near rack and pinion. Any idea what this is? thanks.
Old Jan 20, 2024 | 04:50 AM
Les7311's Avatar
I’ve seen those before when doing spark plug surgery.
I think they came from the area of removing the Plenum/Valve Cover……can’t fully recall
@LtLeary care to chime in Big Brotha?
Old Jan 20, 2024 | 04:55 AM
Les7311's Avatar
A long bolt drops through these…
they come off the valve cover…. Like 8-12 bolts…dAmmitttt??????
. It’s 25 degrees and M tempted to go lift the hood. Still waiti@LtLeary
found it……see 4 of them washer on pic
Old Jan 20, 2024 | 05:20 AM
LtLeary's Avatar
@Les7311. Good detective work. The op is lucky it didn't go down the intake!
Old Jan 20, 2024 | 05:52 AM
Les7311's Avatar
yup yup!!! 🤜🏽👊🏽🤛🏽
Old Jan 20, 2024 | 06:56 AM
WDM's Avatar
WDM
thanks! I double checked, Unfortunately, 4 of them in that picture doesn't have flat top.
Old Jan 20, 2024 | 07:35 AM
Les7311's Avatar
I’ve seen / touch them S$#!%*•* under-the hood ….
@LtLeary U..????
Old Jan 20, 2024 | 07:46 AM
RA030726's Avatar
I'm nutty for Nissans
They go with rubber grommets and let whatever part being secured have some wiggle room. Most likely it's for the air filter box but there are many parts secured that way.
Old Jan 20, 2024 | 09:00 AM
Les7311's Avatar
Ok okay okay (Danny Devito voice)
I was replacing the spark cover tub seals and came across them. Am 99.999% certain. Peep at this
Old Jan 22, 2024 | 05:42 AM
WDM's Avatar
WDM
engine valve cover was not touched during spark plugs change, and those washers in engine valve cover have different color and threads inside.
I also check air filter box, no washer missing.
here is a screenshot of engine valve cover(took in junk yar long time ago):
WDM
Jan 20, 2024 04:19 PM
shaxs
Jan 12, 2014 06:44 AM
K20A2
Mar 11, 2008 09:52 PM
andymax95
Oct 27, 2005 01:32 PM
Stephen Max
Aug 5, 2004 02:39 PM
