Just In: 2011 Maxima NO START
So... long time follower, 1st time in years to post...
Just picked up a 2011 maxima sv for a cheap daily. 270k+ on it. Trans replaced recently. Got on the cheap because of a no start condition. Cranks healthy with a battery charger on it. You hear the whirring of 5 cyl and what sounds like a like of compression on the 6th cyl. Wont begin to start otherwise.
New battery as of 9/23 and I bought this 3/30/24. Battery is dead without a jumper. Could it be a junk battery? I hear the fuel pump turn on when jumped but there is no fuel pressure at the relief valve under the engine.
I haven't dug into much more as of yet since i bought this just yesterday, just want people to throw out ideas. The past seller brought me a dealer code sheet of pcm faults a mile long. Was thinking, low voltage due to power drains, bad fuel pump/clogged/etc. Fuel level shows almost 1/2 tank.
Any common issues related to this? Original key. Only 1 key. Cranks over several cycles healthy but u hear the whirr of the 5 dead cyl and a little compression on the 6th evenly when you hit the push button. Have not tried a new battery or searched for power drains or looked for any fuel pressure before the underhood yet. Just looking to see if anyone else has had similar issues.
2k2MaxiBlue
Feb 14, 2008 11:22 AM
