Nissan maxima cranking but not starting
Old Aug 14, 2024 | 06:17 PM
Miguelo180's Avatar
My nissan maxima 7th gen crank but won't start I changed the fuel injectors, fuel pump, new battery, camshaft sensor, coolant temperature sensor, new maf sensor, new spark plugs, new ignition coils and still nothing is working I have no clue wha else it could be I haven't change the crankshaft sensor but I don't feel like it's that anyhelp?
Old Aug 20, 2024 | 12:42 PM
Zattysis73's Avatar
I'm in the exact same boat can't figure it out. But I also replaced my engine wiring harness!!
Old Aug 21, 2024 | 05:58 PM
LtLeary's Avatar
As some folks are fond of saying...test, don't guess. Are there any codes to help us get started? If not, how about old school Spark and Fuel Tests. Spray a bit of starting fluid in the throttle body. Does it try to start? If not, lets check for spark. Pull a plug and coil and see if you get spark when cranking. If not, we know we have and ignition/wiring/fuse/control problem. But let's do those basics. You really could use a scan tool or at least a code reader.
LB22
Nov 20, 2023 01:37 PM
alimooshe
29
Dec 25, 2021 01:59 AM
Maximaguy99
Nov 14, 2020 08:23 PM
Mike19852607
Feb 20, 2019 03:26 PM
MAHONEY
Mar 14, 2015 02:15 PM
