Does Anyone Know the Color Temp of the LED Headlights?
Old Sep 28, 2015 | 04:26 PM
doctorpullit's Avatar
Question Does Anyone Know the Color Temp of the LED Headlights?
Does anyone know the color temperature of the LED headlights, or how to find it? I've looked in the owner's manual and it is useless.
Old Sep 29, 2015 | 02:40 PM
trsandrew's Avatar
Former Sponsor
Yeah the manual wouldn't say anything as it's not something that is relevant to 99.999999999999999999999999999% of buyers.
The projector is the same as the new Rogue / Murano / Corolla: a Koito projector with Nichia array.
The caveat here is that not all of these models use the same kelvin temp of the LED itself, so it could potentially be 5000K or 6000K. Does it seem bluish at all in person down below the cutoff line?
Trying to match up some fog light bulbs?
Cheers
Old Sep 29, 2015 | 03:42 PM
Cheers
Yes. I'm looking at replacing the halogen fog lights with LEDs. It bugs me that the fogs are yellowish and don't match the LED headlights. The LED bulbs that I like and that are very bright are 6000k. I'm thinking that even if the headlight LEDs are 5000k, it will be close enough, and still will look better than the halogen fog bulbs. What do you think?
This is what it looks like with the halogens:
Old Sep 30, 2015 | 04:30 AM
trsandrew's Avatar
Former Sponsor
I agree with you for sure. LEDs always seem to look bluer than they actually are, so I think you're in good standing if you go with a 6000K fog light bulb.
Old Sep 30, 2015 | 06:13 AM
Thank you very much for your help.
Old Sep 30, 2015 | 07:36 AM
minsbang's Avatar
Does anyone know if it's possible to get the DRL's to match the stock LED headlights? It would have been nice if Nissan gave the DRLs more of a blue-ish tint as well as easier access to change bulbs associated with the headlight piece.
Old Sep 30, 2015 | 11:02 AM
Yeah, it's like Nissan doesn't even want you to mess with any of the lights. The owner's manual states if you need any bulbs replaced to "see your Nissan dealer". Really?! I don't think so. If I'm able to get to it, I'm going to.
As far as changing the DRLs, I don't know. At this point, I was happy to have figured out how to access the fog lights to change the halogens to LEDs.
Old Sep 30, 2015 | 02:40 PM
BobTX10's Avatar
Which LEDs are you going to use?
Old Sep 30, 2015 | 02:46 PM
Originally Posted by BobTX10
How did you access the fog lights? Through the wheel well? Which LEDs will you be using?
I posted this thread yesterday on how to access the fog lights:
https://maxima.org/forums/8th-genera...og-lights.html
These are the LEDs that I ordered today. Another member has recently installed these and said they work great and are very bright:
Amazon.com: JDM ASTAR 1200 Lumens Extremely Bright 144-EX Chipsets H16 5202 TYPE 2 (with 90 degree angle) LED Bulbs with Projector for DRL or Fog Lights, Xenon White: Automotive Amazon.com: JDM ASTAR 1200 Lumens Extremely Bright 144-EX Chipsets H16 5202 TYPE 2 (with 90 degree angle) LED Bulbs with Projector for DRL or Fog Lights, Xenon White: Automotive
Old Sep 30, 2015 | 02:53 PM
BobTX10's Avatar
I had just seen your post after I asked you haha! Thanks for the info. Ill probably do the same if all goes well for you. With those bulbs is it where you just take out the old ones, place the new ones in and that's it?! I replaced my reverse and license plate bulbs for LEDs and it was that easy.
Sucks cause I don't even use the fog lights. I think they look so tacky and embarrasing looking when lit with the led headlights and DRls.
Old Sep 30, 2015 | 04:12 PM
Yes. That's it. They are "plug and play" supposedly. Once you change the fog lights to LEDs, you should be able to use your fog lights "tacky free".
Can you give me a link to the reverse lights and license plate lights LEDs that you used? How did you access the reverse lights?
Old Sep 30, 2015 | 06:10 PM
BobTX10's Avatar
For the reverse lights:
iJDMTOY® Extremely Bright 7.5W High Power 912 921 906 Projector LED Reverse Light Bulbs, Xenon White
For the License plate:
JDM ASTAR Extremely Bright 5730 SMD 194 168 175 2825 W5W T10 LED Bulbs,Xenon White(Brightest T10 Bulb in the market)
To access lights just take out about 6-8 clips from the trunk cover to expose the bulbs and switch them out. It was ridiculously easy and those bulbs are top notch. This advice was recieved by the help of a forum member. The LEDs definitely add a nice touch, especially the license plate. It shines brightly to the ground. I love it. Keep us updated on how the fog lights go!!
Old Sep 30, 2015 | 06:18 PM
Thank you very much. I assume that the bright reverse lights would be helpful for the backup camera at night. My only concern with changing the license plate lights out was that it would be too overpowering for the back of the car and perhaps detract from the "nighttime esthetics" of the rear of the car. Apparently that's not the case.
Old Sep 30, 2015 | 06:27 PM
BobTX10's Avatar
Oh yes I forgot to mention that it helps immensely when reversing at night. I see a lot clearer further. Its great cause i back up into my garage to park with more confidence.
Old Oct 3, 2015 | 09:03 PM
BobTX10, You wanted to be kept posted, so I'm letting you know that I installed the LED fog light bulbs today. They are crazy bright. It took about 20 minutes and it was pretty straight forward.
Old Dec 19, 2015 | 07:34 PM
Christopher Stark's Avatar
Those fogs are crazy bright! Are they distracting to other drivers at all? I want to start with LED headlamps first, any suggestions for that?
Do you find your LED headlamps and foglights when lit together overwhelming?
Old Mar 21, 2017 | 04:04 PM
stikako's Avatar
Cheers
These LED bulbs pictured above, are they right out of the Maxima? Or a Murano? I was considering putting in demon eyes in my Platinum, but the LED bulb isn't serviceable according to the service manuals. Are the LEDs projectors difficult to remove? I have to pull the lens off regardless as I'm also installing Diode Dynamics Switchback LED board for the DRLs. Thinking about doing both at the same time while I have the lens off.
Old Jul 8, 2019 | 10:10 PM
Matthew Scott Smith's Avatar
Google it..duh
Old Jul 9, 2019 | 06:00 AM
Originally Posted by Matthew Scott Smith
Google it..duh
You’re a little late to the game....duh. That was posted almost four years ago. The 2016 Maxima was brand new. There wasn’t any information on Google. That info has long since been figured out. Stop trolling and be useful.
Old Jul 9, 2019 | 04:59 PM
Steptide's Avatar
I know this is an old thread, but can someone educate me on the headlights in the 16-18 maximas. I know the higher trims have led headlights. My sv does not, but could you just purchase oem led's for let's say a 17 platinum, and just out them in an 18 sv?
Old Jul 10, 2019 | 05:54 AM
NisCal17's Avatar
Just buy decent H11 led bulbs.
Old Oct 28, 2019 | 10:58 PM
Navy Sailor's Avatar
Does this apply to to the high beams as well? The high beams don't have a projector, so I wasn't sure if that changes anything.
GWhite
Feb 21, 2020 10:49 AM
doctorpullit
Jul 20, 2019 09:31 PM
dbaray
Jan 14, 2019 07:06 AM
FanaticMadMax
Oct 21, 2017 09:25 AM
justmaxxin
22
Jun 20, 2014 07:30 AM
