Sub and Amp in 2016 Maxima question
Old Dec 30, 2017 | 06:17 AM
  #41
maximaman79's Avatar
Yes it does, SQ and output is great. The sub is getting 600 watts of power which is plenty for an efficient Hybrid Audio Clarus Subwoofer. Function and sound was the top important things when building this. The design and function has a purpose. The grill was designed similar to the front door speaker grill. To follow the oem door panel grill. The grill cloth hides the sub so you don’t see the sub but doesn’t block the sound. Press metal grill is to protect the sub from damage from things in the trunk.
Old Apr 30, 2019 | 08:51 PM
  #42
David Odell's Avatar
Speaker enclosure
How did you build your enclosure?
[/QUOTE]
Old May 1, 2019 | 02:52 AM
  #43
chasewen's Avatar
I have the same LC2i. How did you run your inputs from your rear speakers? Did you tap in before or after the amp? Also, did you use both sets of pos/neg wires? I heard that is what's required but, wasnt too sure about that.
I=maximaman79;9165013]
Yep this is the one I’m using. I’m helping out a guy I know down the street with this install. I usually never use LOC, but I know this one is pretty good. I think I’m going to run the power wire on the glovebox side. Just need to remove it now to get the grommet.
[/QUOTE]
Old Jul 11, 2019 | 07:14 PM
  #44
tbird2340's Avatar
You ever get the answers to this?
Old Jul 12, 2019 | 05:05 AM
  #45
chasewen's Avatar
Nope
Old Jul 13, 2019 | 09:12 PM
  #46
tbird2340's Avatar
Nope
So you didn’t install a sub and amp?
Old Feb 24, 2020 | 04:47 PM
  #47
K7oR0x's Avatar
Nope
Go to this link and follow the highlighted wiring information.
Maxima 7th Gen Bose Amplifier Wiring for LOC
Old May 3, 2020 | 01:36 PM
  #48
kevintbell's Avatar
Originally Posted by Frasierts
I heard from another user on here:
1. Turn off your radio
2. Press and hold the "Menu" button while spinning the volume button
3. Scoll down to ANC ANS feature.
I have done this and will be installing my amp and sub soon as well. Hope this actually helps.
Thanks so much! Turned off ANC & ANS and new sub sounds phenomenal now - was getting ready to take it back!
Old Jul 16, 2020 | 03:19 PM
  #49
AaFabrications Daytona's Avatar
2016 max platinum, aftermarket amp with a LOC
Im getting a vibration noise out of the subs.How can i fix this?
desertbrown27
Apr 1, 2019 09:19 PM
tmas74
Jun 17, 2008 04:51 AM
2001semax
Oct 3, 2004 09:07 PM
hydroMaxNinja
Feb 12, 2003 07:48 PM
respect123
Feb 24, 2001 08:49 AM
