Trailer Hitches
Old Dec 28, 2015 | 07:38 PM
Blasterguy's Avatar
Trailer Hitches
Anyone thinking about a trailer hitch? I'll be looking at either Hidden Hitch or Curt.
Old Dec 29, 2015 | 02:06 PM
Dab's Avatar
Dab
a trailer hitch on a max, OMG say it isnt soooooo, please dont do it!
Old Dec 29, 2015 | 03:05 PM
Richard66's Avatar
Why would you want to, if your owners manual specifically states do not tow with this vehicle?
Old Dec 29, 2015 | 06:16 PM
Dab's Avatar
Dab
ok im not understanding something blasterguy, first you posted about 17 inch winter rims and now you are asking about a trailer hitch, look by no means am i being critical but are you sure you dont want a SUV instead of a 4 door sports sedan?
Old Dec 29, 2015 | 06:25 PM
Blasterguy's Avatar
I take that as a NO then.
Use a bike rack a fair bit and there is always crap to tow; ATV, dump runs, what have you.
The Murano FWD is rated by Nissan at 1500 lbs. It's essentially the same vehicle. I'm not the least worried about "breaking" the Max.
What I need most is the lead on the right wiring harness.
Old Jan 2, 2016 | 07:54 AM
russ.newman@yahoo.com's Avatar
I am also thinking about a trailer hitch for a hitch mounted bike rack. This is a low weight situation with no actual pulling. Any thoughts?
Old Jan 3, 2016 | 09:29 AM
Trailer Hitches
I looked in the Maxima and Altima owners manuals and both say "Don't tow with this vehicle". I then looked at the U-Haul Trailer Hitch listing tool for a 2016 Maxima and it recommend Model 24737. It's $350 installed.
Someone is buying these hitches.
Old Jan 3, 2016 | 07:02 PM
Dano2016's Avatar
FWD not suitable for towing
The simple answer is that front wheel drive doesn't make for a good or safe towing vehicle. The Murano has All wheel drive and there has traction on the rear axle. A front wheel drive vehicle is basically towing it's rear axle and isn't suitable for towing a trailer.
Old Jan 3, 2016 | 08:58 PM
Blasterguy's Avatar
That's ridiculous. AWD Muranos are slip and grip. So essentially they are FWD vehicles. Nissan has the FWD Murano rated to tow the same as the AWD Murano.
I'll be waiting till the spring before I install either a Curt or a Hidden Hitch, but I will post pics for your viewing pleasure.
Old Jan 4, 2016 | 07:29 AM
R1600Turbo's Avatar
No, not really.
Old Jan 4, 2016 | 09:05 PM
Max16SR's Avatar
There must be a reason that Nissan says not to tow with this vehicle. Possible issues could be the transmission can't take the extra load, the brakes can't handle the additional weight, etc. I would trust Nissan and not tow with your Maxima. If it was safe to do, they would allow you to, as it may be a selling point for some people.
The murano suspension and transmission are different parts....It's not essentially the same vehicle as a maxima.
Old Jan 4, 2016 | 10:49 PM
Blasterguy's Avatar
Not going to be bested by a Kia Soul. LOL!
Old Jan 15, 2016 | 04:03 PM
dbahn's Avatar
I just installed one on my 2014 Maxima. The manual doesn't say not to tow anything. It says don't tow a trailer/load greater than 1000 pounds. So I bought a nice aluminum trailer (less than 500 pounds) to use for towing our kayaks, then I use my Frontier to tow heavy loads.
My understanding is that the limitation is based on transmission cooling more than anything else, and the limit is based on towing in hot weather, so I don't think going a little overweight for short distances poses a real problem either.
I got the Curt trailer on Amazon and the Curt wiring kit, both of which can be installed yourself but there are a few tricks that can make it a little easier. (I'm happy to share that info here if anyone is interested.) I did the hitch without an assistant, but most people recommend having a helper lift it into place. The wiring is very easy except that you need to connect directly to the battery for power instead of taking it from the tail light power to avoid problems with the defective bulb fault circuitry.
I actually did this in the past 2 days and have a few steps to go, so I haven't actually towed anything yet, but I don't expect any problems as long as I stick to light loading.
Old Mar 21, 2016 | 05:47 PM
Blasterguy's Avatar
Winter pretty much over so on went a CURT hitch model number 11352. Wiring harness is CURT model number 56294.
The hitch: contrary to instructions, best is to use a 1 3/16 inch OD hole saw placed right in the middle of the 2 pre drilled factory holes that Curt tells you to enlarge. This way the metal plates and bolts go in the frame and slip down with a nice tight fit thru the factory drilled holes. Enlarging them seems to only weaken the install.
Very pleased with the quality
The wiring is great, plug in play except for the fused hot wire. It must go from the battery. From battery go down the firewall, go along the rear brake linings, go over the gas tank, then up over the rear suspension and into the outer fender where there is one drain plug already (passenger side of course).
Other notes: Mufflers must be pulled off which is easy. Very high quality mufflers btw. Heat shields are history. Plastic panel under trunk must come off.
Attached Thumbnails Trailer Hitches-tires-hitch-005.jpg   Trailer Hitches-tires-hitch-006.jpg   Trailer Hitches-tires-hitch-007.jpg
Old Mar 22, 2016 | 04:22 AM
dbahn's Avatar
Yeah, the hot wire is the only annoyance in the wiring. I ran mine from the trunk through the channel below the door frame up under the dash then poked a hole alongside the trunk release, which exits behind the driver side wheel well.
Old Jul 15, 2016 | 12:03 PM
tommie70's Avatar
Hey Blaster Guy, still liking the CURT hitch? I would strictly be using the hitch for a bike rack, nothing else. I wouldn't even need to hook up the tail lights. anyone else install a hitch?
Old Jul 15, 2016 | 12:25 PM
dbahn's Avatar
I'm pleased with mine, towing light loads (small motorcycle) with the Maxima and heavier loads (e.g. half a cord of hardwood) with the Frontier.
I figure that having the lights work just eliminates one excuse for the police to stop me and slow me down . . .
Old Oct 30, 2016 | 12:26 PM
tommie70's Avatar
OH MY GOD WHAT A NIGHTMARE! Worst DIY project ever! So glad it's done. Blasterguy, does it seem flimsy? After putting my rack on there it seems to flex a lot
Old Oct 30, 2016 | 04:37 PM
robtroxel's Avatar
Wrong car to put a hitch on. Why not just get a truck?
Old Oct 30, 2016 | 07:26 PM
zoemayne's Avatar
Kinda ridiculous such a large car isn't recommended for towing. By today's standard it's a full size car. Shouldn't be out of the ordinary to tow a Jet Ski. Certainly one would think it is safe to put a hitch and cargo box as long as you are no trying to load 1000 lbs. Might be preferred vs a roof box.
Old Oct 31, 2016 | 06:22 AM
Jeeper31's Avatar
For a great bike rack look at Seasucker. I have the Talon and absolutely love it. Leaves no marks on the car. Never had a problem with it sticking. Great product.
https://www.seasucker.com/product-category/bike-racks/
Old Mar 14, 2017 | 07:04 PM
compyelc4's Avatar
Thanks for posting the info and photos. I've looked all over the internet trying to find out what a '17 Maxima looks like with a Class I hitch. Yeah, makes the girl look a lot less sporty from behind but once you use the hitch that is priceless.
PS- My wife won't let me put a hitch on her "14 Malibu so I have no choice, and no, a truck is not to my taste. "Put a little peanut butter on my French Croissant please". :-)
Old Mar 15, 2017 | 05:35 PM
tommie70's Avatar
I'm not sure if anyone else has mentioned this, but if you are installing a hitch for a bike rack, be careful which rack you buy. The rack I purchased was really heavy to begin with, plus the bikes, it actually flexes the unibody frame and bounces a lot. I'm sure it's fine for a small trailer but I worry with enough of the bouncing up and down, it will stress fracture the thin gauge metal it is bolted to. I just gotta have faith that the engineers who design these things know what they're doing!
Old Mar 14, 2022 | 01:43 PM
eightball298's Avatar
Towing
Whoops - I missed this one when I stared a new thread on the same topic. Here's what I did with my Dodge Charger:
"Hidden hitch" on a 2011 Dodge Charger Mopar Edition
Mosin Nagant
Dec 12, 2015 02:05 AM
brandonj
Feb 23, 2001 07:06 AM
ericdwong
Feb 22, 2001 05:46 PM
2000MaximaSE
20
Jan 4, 2001 10:27 PM
Aug 30, 2000 04:37 PM
