LED Fog Light
Old Mar 2, 2016 | 09:25 AM
maximafan2016's Avatar
Exclamation LED Fog Light
So a lot of people seem to be having the same issue when it comes to the fog lights which is the moisture issue. I was wondering if anyone swapped to LEDs and did not have moisture issues. If so what LED did you use?
Old Mar 2, 2016 | 09:34 AM
JSROOKS's Avatar
From what I have read in other threads. It really seems like it is a housing issues. I live in AZ so it doesn't rain often. I have not changed mine out yet. I think I will leave them in to see how it does when it rains and test it out.
Old Mar 2, 2016 | 10:16 AM
doctorpullit's Avatar
I replaced mine last September right after I got the car. I haven't had any moisture issues. I think the problem people are having is with the fog light housing. I think people are just noticing it sometimes after they replace the bulbs because they are "aware" of the area after they have worked on it. The housings probably already had an issue, but it had just not been noticed or hadn't rained enough to be evident beforehand. There have been plenty of instances on this forum of people having moisture in their fog lights that HAVE NOT replaced their fog light bulbs.
I used the same bulbs that most have used:
Amazon.com: JDM ASTAR 1200 Lumens Extremely Bright 144-EX Chipsets H16 5202 TYPE 2 (with 90 degree angle) LED Bulbs with Projector for DRL or Fog Lights, Xenon White: Automotive Amazon.com: JDM ASTAR 1200 Lumens Extremely Bright 144-EX Chipsets H16 5202 TYPE 2 (with 90 degree angle) LED Bulbs with Projector for DRL or Fog Lights, Xenon White: Automotive
Old Mar 2, 2016 | 10:31 AM
JSROOKS's Avatar
I know most of the people on Amazon have different cars so they only need two, but with the Maxima needing two per side is it an overkill at all?
Old Mar 2, 2016 | 10:53 AM
I don't think so, personally, but everyone is different. They are bright, for certain, but I don't think they are obnoxious or blinding to other drivers.
Old Mar 2, 2016 | 11:07 AM
JSROOKS's Avatar
Awesome I will definitely have to pick up a couple pairs of them for sure. Doesn't look so bad to install.
Old Mar 2, 2016 | 11:17 AM
Clouded's Avatar
I noticed my moisture issue after a self service car wash. I will be looking to see if I can identify how the water got in if at all possible. I want these bulbs to work, I really like the color and the price was nice.
Old Mar 2, 2016 | 03:13 PM
Max8's Avatar
I agree. I used these same lights from Amazon too and have not had any moisture issues.
Old Mar 3, 2016 | 05:37 AM
16sjmax's Avatar
Holy crap!!
All $186.99 Add to Cart Nite-Lux LED Kit - Nite-Lux LED Kit - H16 Pair
Part Number: 270016
Stock: Available
• 100% High Temperature Nylon construction
• Newest & most advanced LED Kit available in the world
• Packed with technology Constant Current CPU, EMC (anti-interference)
• Miniaturized lamp, tower, and ballast, 40% reduction in size
• High Lumen output - 2500 lumens each
• A Putco exclusive 100% COPPER (Cu) Weave cloth heat-sink
• Copper cloth heat-sink allows for installation in compact places
• No noisy fan which is prone to failure
• Cree LED
• 360 Degree Light Output
• IP68 IP65 Shock Proof
• Lifespan > 50,000 hours
Close
$186.99
Old Mar 3, 2016 | 05:45 AM
Part Number: 270016
Stock: Available
• Cree LED
Close
$186.99
What the heck?! That is the ugliest thing I've seen as far as a "bulb" goes.
Old Mar 3, 2016 | 05:50 AM
Frasierts's Avatar
Go with Diode Dynamics XML2's they are pricey but cheaper than the ones above. $120/pair. Diode is a great company and high quality products. I just got mine in the mail and will be installing this weekend. All my other bulbs that are now LED are from Diode as well.
Old Mar 3, 2016 | 06:04 AM
You guys need to stop buying crappy drop in bulbs and buy these actual LED housings. No plug and play bulb compares in brightness and width.
https://www.theretrofitsource.com/co...pe-nissan.html
I can get them a good bit cheaper so PM me if interested.
EDIT: Thought this was the 7th gen section. Whoops! Still wouldn't waste money on drop in LED bulbs.
Old Mar 3, 2016 | 08:14 AM
That won't fit a 2016, will it?
Old Mar 3, 2016 | 01:05 PM
Sorry, thought this was the 7th gen section. Check my edit.
trasmadean
Aug 10, 2021 07:14 AM
Nykerinsd
Jul 30, 2016 06:40 AM
maxima703
Feb 14, 2016 08:58 AM
The_Fixer
Feb 4, 2016 07:58 AM
GregL65
Feb 3, 2016 10:29 AM
